My domains are: sollyst.duckdns.org, sollysten.duckdns.org, solhjemmet.duckdns.org
I ran this command: for the two first domains I am using an add on from home assistant, for solhjemmet I am running the commands from the dehydrated tool from github (https://github.com/lukas2511/dehydrated.git) commands: ./dehydrated --register --accept-terms, ./dehydrated -c. Which I suspect is at the back end of the addon from home assistant (haven't been looking).
All seems fine I get the that everything is fine. Sorry can't paste the return messages here, I dont have the return availabe. But I cannot achieve what I want for any of the domains, the two first are for the same server, the latter for another. I cannot manage to remotely connect to my home assistant on the servers, it might be the port forwarding, (set up with 443->8123 and the ip adress of the server, which is made static) but it might be other issues..
First is a Compulab fitlet mini computer, second is a raspberry pi 4
First is a Linux Mint 19.1 Tessa, second is raspberry OS buster
telenor, don't think this is applicable though
Yes
Well, sort of the for the first, not so for the pi
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Not using certbot
My question: As I have written it might not be the encryption that is my issue, but when investigating all parts of my problem I bumped into something here on your pages, to check with dnsviz.net. Here are the results of that check: https://dnsviz.net/d/sollyst.duckdns.org/dnssec/ I understand nada of this, but it indicates that something is wrong I guess could, you enlighten me? The output is more or less the same for all three domains
