Cerbot failed using HA, DuckDNs and Let's
I am using Let's encrypt in Home Assistant and I have an error when using it with my domain vicitocande.duckdns.org
Requesting a certificate for vicitocande.duckdns.org
Domain: vicitocande.duckdns.org
Type: connection
Detail: 83.55.31.67: Fetching http://vicitocande.duckdns.org/.well-known/acme-challenge/lt8VrfYFk1K7RCoWJ0Tq2Egm0SG7oxG1P5FcbklwI3o: Timeout during connect (likely firewall problem)
Can you help me?
Hello @Vicitocande, welcome to the Let's Encrypt community. :slightly_smiling_face:
Using the online tool Let's Debug the results are an ERROR here https://letsdebug.net/vicitocande.duckdns.org/1312331
Best Practice - Keep Port 80 Open
Using nmap (from an IPv4 Address only) I find no ports opens.
$ nmap -Pn vicitocande.duckdns.org
Host discovery disabled (-Pn). All addresses will be marked 'up' and scan times will be slower.
Starting Nmap 7.91 ( https://nmap.org ) at 2022-12-25 11:20 PST
Nmap scan report for vicitocande.duckdns.org (83.55.31.67)
Host is up.
rDNS record for 83.55.31.67: 67.red-83-55-31.dynamicip.rima-tde.net
All 1000 scanned ports on vicitocande.duckdns.org (83.55.31.67) are filtered
Nmap done: 1 IP address (1 host up) scanned in 203.57 seconds
