Problem with http://site.com:443
Centos 7 nginx + ssl
Did the installation through - sudo certbot --nginx
The certificate works.
BUT!!!
Users from search engines go to http://site.com:443
And the error is: 400 Bad Request The plain HTTP request was sent to HTTPS port nginx
Please share your domain name. There are too many potential causes for us to be able to help you by blind guessing.
Hi @vovckalexei
there is no such redirect visible
| Domainname | Http-Status | redirect | Sec. | G |
| • http://helpessay.tk/ | ||||
| 95.215.206.22 | 301 | https://helpessay.tk/ Html is minified: 108,54 % | 0.063 | A |
| • http://www.helpessay.tk/ | ||||
| 95.215.206.22 | 301 | https://www.helpessay.tk/ Html is minified: 108,54 % | 0.050 | A |
| • https://www.helpessay.tk/ | ||||
| 95.215.206.22 | 301 | http://helpessay.tk/ Html is minified: 108,54 % | 3.280 | F |
| • https://helpessay.tk/ 95.215.206.22 GZip used - 6410 / 15250 - 57,97 % Inline-JavaScript (∑/total): 0/0 Inline-CSS (∑/total): 0/0 | 200 | Html is minified: 105,21 % | 3.763 | B |
Two correct redirects http -> https, one wrong (https -> http), but without a port.
So it's an old, not longer valid entry -> ignore it.
Or use the Google console to remove the entry.
But searching I can't find such a link.
The answer is normal - http via a working https port is always http status 400 - Bad Request.
How to do it right (https -> http)?
What program tested the site for errors?
You have already a (wrong) redirect. Find that and modify it.
That's an own online tool https://check-your-website.server-daten.de/?q=helpessay.tk
Created to make it easier to find errors in configurations. Most ideas are from this forum.
Help, I can not understand.
Everything was automatically registered for me when I installed the certificate.
Config File: https://dropmefiles.com/Vd2U1
Please read your config file. There is your wrong redirect - on top.
I tried to change, but nothing worked. Correct what is wrong.
server
server_name www.site.com;
rewrite ^ https://site.com$request_uri? permanent;
ssl_certificate /etc/letsencrypt/live/alsb.ru/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/alsb.ru/privkey.pem; # managed by Certbot
Please read the documentation of
Don't use commands without knowing what they are doing. That's always wrong.
As soon as I haven’t tried, it doesn’t work, please help. What am I doing wrong?
server_name www.site.tk;
return 301 https://site.tk$request_uri;
What doesn't work?
What's the error?
