Problem with generating certificate
Normal Requested 23m cert-manager Created new CertificateRequest resource
My domain is: authproxy-uat.skoda-auto.com/
Deployed to azure aks
Hello @Praveena, welcome to the Let's Encrypt community. ![]()
Let’s Encrypt offers Domain Validation (DV) certificates.
Thus you need to own and have control over the Domain Name (or have a subdomain under an existing domain name, for example pointed to your server by your employer or school) you wish to obtain a certificate for, from an ICANN Accredited Registrar.
For Let’s Encrypt to issue a Domain Validation (DV) certificate Domain Validation must happen
and it is a CA/Browser Forum Baseline Requirement.
Best Practice - Keep Port 80 Open
What IP addresses does Let’s Encrypt use to validate my web server?
Let’s Encrypt does not publish a list of IP addresses we use to validate,
and these IP addresses may change at any time.
Let's Encrypt uses Multi-Perspective Validation Improves Domain Validation Security - Let's Encrypt
Since these are Domain Validation (DV) certificates the Domain Name System (DNS) is used extensively in the validation process as well a allowing us to assist here on Let's Encrypt community.
DNS Queries need to give consistent results from any location on the Internet, all your authoritative DNS Servers for the Domain need to also give consistent results as well.
Testing and debugging are best done using the Staging Environment as the Rate Limits are much higher.
And to assist with debugging there is a great place to start is Let's Debug.
Thank you for assisting us in helping YOU!
