Problem with certificate renewal
My domain is: matrixtest.lightshiplabs.org
I ran this command: doas certbot renew
Processing /etc/letsencrypt/renewal/matrixtest.lightshiplabs.org.conf
Renewing an existing certificate for matrixtest.lightshiplabs.org
  Domain: matrixtest.lightshiplabs.org
  Type:   unauthorized
  Detail: 70.109.163.54: Invalid response from http://matrixtest.lightshiplabs.org/.well-known/acme-challenge/jU_FdAz1vzcHx6KkaizpP4ayDbmUMxyr96xac1CCLbA: 400
Failed to renew certificate matrixtest.lightshiplabs.org with error: Some challenges have failed.
  /etc/letsencrypt/live/matrixtest.lightshiplabs.org/fullchain.pem (failure)
My web server is (include version): nginx version: nginx/1.26.2
The operating system my web server runs on is (include version): Alpine Linux 3.20.3
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.10.0
Misc. Information: The SSL cert was valid, as seen from crt.sh | matrixtest.lightshiplabs.org, and the directory structure of /etc/letsencrypt appears to be correct. I'm not really sure why the SSL cert for this server is not renewing. I can also navigate to http://matrixtest.lightshiplabs.org/ in a web browser, which does correctly redirect to https://matrixtest.lightshiplabs.org/, but again the SSL cert there has expired.
Welcome @josh7
Was that from your local network? Because HTTP requests to that domain give an HTTP 400 Error when I try from the public internet. HTTPS requests give a 200 OK reply (when ignoring the expired cert). So, it looks like something unique to your HTTP port 80 handling.
Thank you for your help. I am using HAProxy upstream with its Proxy Protocol and had forgotten to add proxy_protocol for port 80 in my nginx config. It's now working as expected.
