Problem with certbot and nginx
I need help setting renewing the certificate for my domain. I’m not that experienced with it but I am trying to use nginx. I used this guide and got it to work the first time. But now I tried to renew & replace the cert manually to make sure it works and it doesn’t. By now I have completely removed nginx with all settings and reinstalled it. I then set up the nginx with the settings you can find below (sites-enabled is symlinked)
I also removed ufw and checked iptables (is empty).
What can I do to troubleshoot this?
nginx sites-available conf
# Listen HTTP
listen 80;
server_name api.frizzelblizzel.de;
# Define LE Location
location ~ ^/.well-known/acme-challenge/ {
default_type “text/plain”;
root /var/www/html;
# Else Redirect to HTTPS // API
# location / {
# return 301 https://$host$request_uri;
certbot --nginx
Failed authorization procedure. api.frizzelblizzel.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://api.frizzelblizzel.de/.well-known/acme-challenge/MRrTbVIii7617xjQuhLrhkP7osJuTtIzD_qF5oVwbQA: Timeout during connect (likely firewall problem)
nginx version: nginx/1.14.2
Debian 10
certbot 0.31.0
The config is a bit "constrained".
Because of the temporary removal of the redirect there is no root or action to take for anything other than challenge requests.
In the interim, try adding a root for the requests out of the challenges.
If that doesn't correct the problem, try using:
certbot --nginx --webroot -w /var/www/html -d api.frizzelblizzel.de
OOOOH!
And let's not overlook the obvious:
Make sure that port 80 can reach your system.
Taking nothing for granted…
Let’s confirm your Internet IP with what global DNS says:
Address:  207.180.247.98
Please show the output of:
curl ifconfig.me
Thank you for responding to my question
I changed the config to the following to make it less constrained and restarted nginx:
# Listen HTTP
listen 80;
  default_type "text/plain";
  root         /var/www/html;
  root         /var/www/html;
#    location / {
curl ifconfig.me
207.180.247.98root@vmd49804:~#
I'm not sure how to do this. I tried this site https://www.yougetsignal.com/tools/open-ports/ and it says port 80 is closed.
I also ran
netstat -tnlp | grep -w 80
output:
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 15679/nginx: master
That is the expected IP- GOOD.
Than means NGIX is listening on port 80.
The last hurdle is ensuring the firewall/router is port forwarding the outside IP:80 to your inside IP:80
Or if it is directly on the Internet [very likely], that the local firewall is not blocking port 80.
Speak with your hosting provider about that or search their site for help on how to do that.
Hmmm it’s a VPS and the cert creation worked before so I dont think it is a problem on the provider side.
I used sudo iptables -F to delete all rules and sudo iptables -L returns:
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
so no rules.
I even removed ufw completely.
What else could block the port?
Thank you again for the response and your patience
How about:
sudo ufw status
Not too sure about this statement:
EDIT: It might be possible that the "rules" remain after the program is "removed"
Otherwise, there must be some “control panel” or such that is preceding your system.
And ask you HSP if they can think of anything (that could be blocking).
Thanks again for your time. The problem was an apache2 server that was somehow preinstalled on the VPS.
It was only after I restartet the server that nginx reported problems starting/restarting and then I saw that apache was listening on port 80. After removing apache everything worked.
