Problem with active let's Encrypt on Ubuntu 14.04 on Amazon AWS
Please help my solve this problem
Ubuntu 14.04
Apache with Virtual Host
I want to I want to install let’s encrypt only in a virtual host
i following this guide:
but when after first installation that It seems to have gone well. nothing works.
here the result if now i restart installation
-rwxr-xr-x 1 root root 46237 Jan 26 21:05 certbot-auto*
ubuntu@ixxxx:/usr/local/sbin$ sudo certbot-auto --apache -d xxxx.com -d www.xxxx.com
tls-sni-01 challenge for xxxx.com
tls-sni-01 challenge for www.xxxx.com
Waiting for verification…
Failed authorization procedure. www.xxxx.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 99.99.99.99:443 for TLS-SNI-01 challenge, xxxx.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 99.99.99.99:443 for TLS-SNI-01 challenge
    Domain: www.xxxx.com
    Type: connection
    Detail: Failed to connect to 99.99.99.99:443 for TLS-SNI-01
    challenge
    Domain: xxxx.com
    Type: connection
    challenge
thankyou
Here : it seems only for certbot
Did your website work before trying install LE ssl ?
  • after : add same for 443 port (the one used for ssl)
Yes he works also now in http, but no https
OK, good,
Then i think (but unsure here) you have 2 solutions :slight_smile:
Force certbot to use http challenge sudo certbot-auto --apache --preferred-challenges "http" -d example.com -d www.example.com
Create a temporary self-signed ssl certificate
and activate ssl on your site with ssl certificate.
With the second way : it’s best :
  1. You learn how to create a self signed certificate
  2. You just have to update the certificate part when you have your LE certificate and key chain
thank you, next week I’ll try
Ensure that inbound connections are allowed for port 443 in the Security Groups associated with your AWS instance.
Thanks for your help… solved!!!
Security Groups associated with my AWS instance was not configured
