Problem with AAAA
My domain is: eveil.site
I ran this command: "le's debug" on a browser
It produced this output: AAAANotWorking
eveil.site has an AAAA (IPv6) record (2a01:e0a:af9:67f0:7387:ff83:dfae:c94c) but a test request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address. You should either ensure that validation requests to this domain succeed over IPv6, or remove its AAAA record.
My web server is (include version): apache 2.4.68
The operating system my web server runs on is (include version): raspberrypios
My hosting provider, if applicable, is: self hosting
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 4.0.0
The message tells you exactly what to do.
You have to verify is the IP address in the DNS matching the IP address in the system? Please check is the firewall open for inbound access on port 80/443 for that IP address?
And ensure Apache is serving the correct HTTP content from that IPv6 address.
Thanks a lot for your replies.
I've deleted the AAAA in dns. And i changed an entrie in website database. It's ok. I don't know if it's plenty secure without AAAA entrie. I've ran certbot script.
Thanks again for your job.
