Problem while adding a subdomain to a certificate
acupuncture-nantes.fr
certbot --apache
1: acupuncture-ancenis.fr
2: www.acupuncture-ancenis.fr
3: acupuncture-nantes.fr
4: mail.acupuncture-nantes.fr
5: www.acupuncture-nantes.fr
6: calligraphie-chinoise-paris.fr
7: www.calligraphie-chinoise-paris.fr
8: mtc-nantes.fr
9: admin.mtc-nantes.fr
10: consult.mtc-nantes.fr
11: poterie-aisne.fr
12: www.poterie-aisne.fr
13: r0dy.net
14: a.r0dy.net
15: admin.r0dy.net
16: mtc.r0dy.net
17: tlvtle.r0dy.net
18: www.r0dy.net
19: terre-encre.net
20: www.terre-encre.net
blank to select all options shown (Enter 'c' to cancel): 4
http-01 challenge for mail.acupuncture-nantes.fr
Challenge failed for domain mail.acupuncture-nantes.fr
Apache/2.4.41
Ubuntu 20.04
OVH
no
certbot 0.40.0
all other domains and subdomains listed above, i didnt get any problem to create/add certificates.
Here is /etc/apache2/sites-enabled/acupuncture-nantes.fr.conf :
    <VirtualHost *:80>
    ServerAdmin thomas@acupuncture-nantes.fr
    ServerName acupuncture-nantes.fr
    ServerAlias www.acupuncture-nantes.fr mtc-nantes.fr mail.acupuncture-nantes.fr
    DocumentRoot /var/www/acupuncture-nantes.fr
    <Directory /var/www/acupuncture-nantes.fr/>
            AllowOverride All
    </Directory>
RewriteEngine on
RewriteCond %{HTTP_HOST} =acupuncture-nantes.fr [OR]
RewriteCond %{HTTP_HOST} =www.acupuncture-nantes.fr [OR]
RewriteCond %{HTTP_HOST} =mail.acupuncture-nantes.fr [OR]
RewriteCond %{HTTP_HOST} =mtc-nantes.fr
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
and here is /etc/apache2/sites-enabled/acupuncture-nantes.fr-le-ssl.conf :
<IfModule mod_ssl.c>
<VirtualHost *:443>
    Alias /mail /usr/share/roundcube
            AllowOverride All
    </Directory>
SSLCertificateFile /etc/letsencrypt/live/acupuncture-nantes.fr/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/acupuncture-nantes.fr/privkey.pem
</VirtualHost>
</IfModule>
and here is my dns zone :
@ 10800 IN A 193.70.86.96
admin 10800 IN CNAME @
consult 10800 IN CNAME @
mail 10800 IN CNAME @
www 10800 IN CNAME @
@ 10800 IN MX 10 mail.acupuncture-nantes.fr.
My goal here is to enable ssl for mail transfers (dovecot installed and running), i just added mail.acupuncture-nantes.fr in the web server aliases because i thought it would solve the problem, at first, and allow me to add the certificate.
Any help would be very welcome :slight_smile:
Hi @r0dy
your vHost definition has 4 domain names.
But you want to create a certificate with one domain name.
Conclusion: There is no matching vHost, Certbot has problems to find the correct vHost.
  • Create one certificate with 4 domain names used in your vHost (or)
  • create a new vHost and remove the mail subdomain from that vHost.
Check your config with apachectl -S.
Hi @JuergenAuer , thank you very much for your reply.
I think I understand your explanation, but i'm having troubles to apply the solution.
I deleted the certificate acupuncture-nantes.fr and all the -le-ssl.conf files of the vhosts
Then i did :
certbot --apache -d acupuncture-nantes.fr --> ok
and then
certbot --apache --> I got the same error.
Then i deleted the certificate again and tried :
certbot --apache -d acupuncture-nantes.fr -d mtc-nantes.fr -d www.acupuncture-nantes.fr -d mail.acupuncture-nantes.fr
--> same error.
Then i removed the mail alias from the conf file and tried :
certbot --apache -d mail.acupuncture-nantes.fr
--> We were unable to find a vhost with a ServerName or Address of mail.acupuncture-nantes.fr.
(though i don't need a mail vhost...)
What did I do wrong ?
Ok i got it working.
As I said, I removed the mail subdomain from the apache conf file.
Then I created a new vhost in its own conf file for the mail subdomain (which i redirected to my roundcube interface, so it proved useful in the end).
Then i created its single certificate mail.acupuncture-nantes.fr
Then i re-created all the other certificates for all my vhosts with certbot --apache.
Now it works.
Thanks !
