Hello
metro.davidestebanmunoz.com
sudo certbot certonly --webroot -w /home/ubuntu/dockers/reverse/etc_nginx/bot -d metro.davidestebanmunoz.com
An unexpected error occurred:
File "/usr/lib/python3/dist-packages/requests/models.py", line 379, in prepare_url
scheme, auth, host, port, path, query, fragment = parse_url(url)
File "/usr/lib/python3/dist-packages/urllib3/util/url.py", line 392, in parse_url
return six.raise_from(LocationParseError(source_url), None)
File "", line 3, in raise_from
urllib3.exceptions.LocationParseError: Failed to parse: https://acme-v02.api.letsencrypt.org/directory
requests.exceptions.InvalidURL: Failed to parse: https://acme-v02.api.letsencrypt.org/directory
nginx
no
or certbot-auto --version
if you're using Certbot):
0.40.0
