Problem to create ssl cert on nginx
My domain is: odisseo.io
  1. create a directory
    /etc/letsencrypt
  2. cd /etc
  3. cd letsencrypt
    sudo wget https://dl.eff.org/certbot-auto
sudo chmod a+x certbot-auto
cd
cd
then I stopped all service
sudo /etc/letsencrypt/certbot-auto --nginx
Congratulations! You have successfully enabled https://odisseo.io
https://www.ssllabs.com/ssltest/analyze.html?d=odisseo.io
    /etc/letsencrypt/live/odisseo.io/fullchain.pem
    /etc/letsencrypt/live/odisseo.io/privkey.pem
    Your cert will expire on 2019-01-14. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again with the ā€œcertonlyā€ option. To non-interactively renew all
    of your certificates, run ā€œcertbot-auto renewā€
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
**then when i go I go to set up the deafult_ssl.vhost file adding this two line
ssl_certificate ā€œ/etc/letsencrypt/live/odisseo.io/fullchain.pemā€;
ssl_certificate_key ā€œ/etc/letsencrypt/live/odisseo.io/privkey.pemā€;
and I restart nginx it return two permission errors, fopen I cant read file **
For me is the first time and my head is on fire …
this is the file deafult_ssl.vhost
listen 443 ssl;
#listen [::]:443 ssl;
server_name _;
include /jet/etc/nginx/conf.d/document_root.settings;
 #   ssl_certificate "/jet/etc/pki/tls/certs/www.crt";
  #  ssl_certificate_key "/jet/etc/pki/tls/private/www.key";
  ssl_certificate /etc/letsencrypt/live/odisseo.io/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/odisseo.io/privkey.pem;
# ssl params
    #ssl_session_cache shared:SSL:1m;
    #ssl_session_timeout  10m;
    #ssl_ciphers PROFILE=SYSTEM;
    #ssl_prefer_server_ciphers on;
    # Load configuration files for the default server block.
    include /jet/etc/nginx/conf.d/*.inc;
    include /jet/etc/nginx/sites-enabled/*;
My web server is (include version): Google Cloud Platform, Compute Engine , http://jetware.io/appliances/jetware/lemp7_optimized_g2-170723/profile
Hi @RickyIta68
there is a running nginx-server. And the https - version has a self signed certificate.
So it looks that your domain uses an individual server configuration, not the default configuration.
Check these two directories
if there is a configuration file with
server_name odisseo.io
and add there the certificate files.
Hi Jurgen, thanks for the reply …
now I will give a look to all the configuration files and also I will post the exact wording of the error as reported on the console. I am sorry when I wrote yesterday I was very tired and I posted everything very quickly. I will see to be more precise in the description.
this is the exact error when I do the command : $ nginx -s reload
nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/odisseo.io/fullchain.pem") failed (SSL: error:0200100D:system library:fopen:Permission denied:fopen(’/etc/letsencrypt/live/odisseo.io/fullchain.pem’,ā€˜r’) error:2006D002:BIO routines:BIO_new_file:system lib)
I tryed also to give through sudo chmod the permission 600 to private key and 644 to the public key but the error reappears identical.
Maybe I’m missing something in the configuration.
Hi @RickyIta68,
You should not modify the perms inside /etc/letsencrypt/, instead reload nginx as root or using sudo:
sudo nginx -s reload
Cheers,
sahsanu
thanks, I tryed now with sudo nginx -s reload and I have now this error :
nginx: [alert] kill(28794, 1) failed (3: No such process)
Restart nginx:
sudo service nginx restart
or
sudo systemctl restart nginx
I did it but nginx seems to be capricious:
Job for nginx.service failed because the control process exited with error code.
See "systemctl status nginx.service" and "journalctl -xe" for details.
$ sudo systemctl restart nginx
You should use the two commands to know what is the error preventing nginx to start:
sudo systemctl status nginx.service
sudo journalctl -xe
thanks Sahsanu ...
I did it ...
ā— nginx.service - A high performance web server and a reverse p
roxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor pres
et: enabled)
Active: failed (Result: exit-code) since Wed 2018-10-17 20:2
2:00 UTC; 11min ago
Docs: man:nginx(8)
Process: 25833 ExecStop=/sbin/start-stop-daemon --quiet --stop --retry Q
UIT/5 --pidfile /run/nginx.pid (code=exited, status=1/FAILURE)
Process: 12993 ExecStart=/usr/sbin/nginx -g daemon on; master_process on
; (code=exited, status=1/FAILURE)
Process: 12991 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_p
rocess on; (code=exited, status=0/SUCCESS)
Main PID: 24524 (code=killed, signal=KILL)
Oct 17 20:21:58 lemp7-optimized-g2-1-vm nginx[12993]: nginx: [emerg] bind(
) to 0.0.0.0:443 failed (98: Address already in use)
Oct 17 20:21:59 lemp7-optimized-g2-1-vm nginx[12993]: nginx: [emerg] bind(
) to 0.0.0.0:80 failed (98: Address already in use)
Oct 17 20:22:00 lemp7-optimized-g2-1-vm nginx[12993]: nginx: [emerg] still
could not bind()
Oct 17 20:22:00 lemp7-optimized-g2-1-vm systemd[1]: nginx.service:
Control process exited, code=exited status=1
Oct 17 20:22:00 lemp7-optimized-g2-1-vm systemd[1]: Failed to star
t A high performance web server and a reverse proxy server.
Unit entered failed state.
Failed with result 'exit-code'.
with the second command : sudo journalctl -xe
I recived a very long text result :
there are some red lines :
Oct 17 20:21:11 lemp7-optimized-g2-1-vm systemd[1]: Failed to star
Oct 17 17:37:34 lemp7-optimized-g2-1-vm sshd[11809]: error: maximu
m authentication attempts exceeded for root from 109.173.19.23 port 39365
ssh2 [preauth]
There is something already listening on port 443, maybe is nginx itself or is another service:
sudo netstat -ptan | grep :443
or
sudo ss -tlpn | cat | grep :443
But maybe the fast solution is to restart your server.
LISTEN 0 128 *:443 : users:(("nginx",pid=3520,fd=8),("nginx",pid=3518,fd=8))
So for some reason nginx is not stopping, you could kill the nginx processes or restart your server.
sudo killall nginx
or
sudo kill 3520 3518
If the processes don’t die, force the kill
sudo killall -s KILL nginx
or
sudo kill -9 3520 3518
restart
/jet/etc/init/exim: not running (no pid-file)
/jet/etc/init/nginx: not running (no pid-file)
/jet/etc/init/exim: start error
nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/odisseo.io/fullchain.pem") failed (SSL: error:0200100D:system library:fopen:Permission denied:fopen('/etc/letsencrypt/live/odisseo.io/fullchain.pem','r') error:2006D002:BIO routines:BIO_new_file:system lib)
/jet/etc/init/nginx: start error
sudo nginx -s reload is ok
but with nginx -s reload
nginx: [error] open() ā€œ/jet/run/nginx/nginx.pidā€ failed (2: No such file or directory)
I didn’t see that you are using something called jetware, I’ve no idea how you should start/stop these services, you should read the doc to do that, also, for some reason your services are not starting as root, they are in a jail (chroot) or are doing something more but whatever is the reason, the services are not starting because they can’t access the files inside /etc/letsencrypt/live/odisseo.io/, so, or you check the reason your jetware services can’t access those files or you can manually copy the cert (fullchain.pem and privkey.pem) (as root) to a path that jetware can access ( I suppose inside /jet/ dir) and modify nginx and exim to use that path.
Great, I understand I will try tomorrow, I’m really melted now :blush: thank you very much
I hope you can get it up and running soon, anyway, I see there is an appliance including Let’s Encrypt http://jetware.io/appliances/jetware/lemp7_optimized_ssl_le so maybe you should take a look to that.
thank you , yes, I will give a look
As I said, the problem is that you are using jetware and the services are started as a normal user inside an isolated environment create by jetware so nginx can’t access /etc/letsencrypt/live/ dir to read the cert and privkey for your domain so you could copy it inside the jet env.
1.- Create a dir where you will save the fullchain.pem and privkey.pem files.
mkdir /jet/prs/le/
2.- Copy the files using sudo:
sudo cp /etc/letsencrypt/live/odisseo.io/fullchain.pem /jet/prs/le/
sudo cp /etc/letsencrypt/live/odisseo.io/privkey.pem /jet/prs/le/
3.- Now change the perms and owner of these files (change the word user by your real user and group by the real group for your user):
sudo chmod 600 /jet/prs/le/*.pem
sudo chown user:group /jet/prs/le/*.pem
4.- Modify the nginx conf file default_ssl.vhost and replace the path in ssl directives:
This:
Should be replace by this:
  ssl_certificate /jet/prs/le/fullchain.pem;
  ssl_certificate_key /jet/prs/le/privkey.pem;
5.- Reload nginx using /jet/enter command
/jet/enter reload nginx
The problem is that you should create a script to perform these steps automatically and modify the renewal conf for your domain so certbot-auto can renew your cert and copy the files to the jetware env and reload nginx automatically or as I commented in another post, use the jetware’s appliance that includes the Let’s Encrypt package, it should be easier…
Good luck,
sahsanu
