Nginx not finding fullchain.pem
joshcampana.com
nginx version: nginx/1.14.2
"Raspbian GNU/Linux 10 (buster)"
** Linux 5.4.79-v7l+ armv7l**
self hosted with static public IP on Raspberry 4
No
certbot 0.31.0
After a couple rough starts, I got the following:
root@oerlikon:/var/www/html# certbot --nginx
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter 'c' to cancel): joshcampana.com dreadnought-brewing.com dreadnought-welding.com dreadnoughtfabrication.com dreadnoughtmetalworks.com dreadnoughtwelding.com dreadnoughtpc.com hotmessexpresscreations.com weldingshit.com
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/joshcampana.com.conf)
What would you like to do?
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/default
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Redirecting all traffic on port 80 to ssl in /etc/nginx/sites-enabled/default
Congratulations! You have successfully enabled https://joshcampana.com,
https://dreadnought-brewing.com, https://dreadnought-welding.com,
https://dreadnoughtfabrication.com, https://dreadnoughtmetalworks.com,
https://dreadnoughtwelding.com, https://dreadnoughtpc.com,
https://hotmessexpresscreations.com, and https://weldingshit.com
SSL Server Test: joshcampana.com (Powered by Qualys SSL Labs)
SSL Server Test (Powered by Qualys SSL Labs)
SSL Server Test: dreadnoughtmetalworks.com (Powered by Qualys SSL Labs)
SSL Server Test: dreadnoughtpc.com (Powered by Qualys SSL Labs)
    /etc/letsencrypt/live/joshcampana.com/fullchain.pem
    /etc/letsencrypt/live/joshcampana.com/privkey.pem
    Your cert will expire on 2021-03-29. To obtain a new or tweaked
    with the "certonly" option. To non-interactively renew all of
    Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
    Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
however nginx -t is not happy
root@oerlikon:/etc/letsencrypt/live# nginx -t
nginx: [emerg] SSL_CTX_load_verify_locations("/etc/letsencrypt/live//fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such fil e or directory:fopen('/etc/letsencrypt/live//fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file error:0B084002:x509 certif icate routines:X509_load_cert_crl_file:system lib)
nginx: configuration file /etc/nginx/nginx.conf test failed
root@oerlikon:/etc/letsencrypt/live# ls -al joshcampana.com/
total 12
drwxr-xr-x 2 root root 4096 Dec 29 18:12 .
drwx------ 3 root root 4096 Dec 29 18:45 ..
-rw-r--r-- 1 root root 692 Dec 29 18:12 README
lrwxrwxrwx 1 root root 39 Dec 29 18:12 cert.pem -> ../../archive/joshcampana.com/cert1.pem
lrwxrwxrwx 1 root root 40 Dec 29 18:12 chain.pem -> ../../archive/joshcampana.com/chain1.pem
lrwxrwxrwx 1 root root 44 Dec 29 18:12 fullchain.pem -> ../../archive/joshcampana.com/fullchain1.pem
lrwxrwxrwx 1 root root 42 Dec 29 18:12 privkey.pem -> ../../archive/joshcampana.com/privkey1.pem
I do a bit of research and chown to www-data. same error. then I remove the sym links and copy the files over, now I get a similar, but different error:
nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/joshcampana.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/joshcampana.com/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
root@oerlikon:/etc/letsencrypt/live/joshcampana.com# ls -al
total 24
drwxr-xr-x 2 www-data root 4096 Dec 29 19:23 .
drwx------ 4 root root 4096 Dec 29 19:23 ..
-rw-r--r-- 1 www-data root 2110 Dec 29 19:23 cert1.pem
-rw-r--r-- 1 www-data root 1586 Dec 29 19:23 chain1.pem
-rw-r--r-- 1 www-data root 3696 Dec 29 19:23 fullchain1.pem
-rw------- 1 www-data root 1704 Dec 29 19:23 privkey1.pem
Lines that I believe are relevant from nginx/sites-available/default:
ssl_certificate /etc/letsencrypt/live/joshcampana.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/joshcampana.com/privkey.pem; # managed by Certbot
I just noticed that nginx is looking for fullchain.pem, but the file is called fullchain1.pem. I renamed it to fullchain.pem (so now same as the symlink) and I get the SSL_CTX error again along with the instead of my domain.
You just broke your certbot.
Sure did, but hey backups. a quick cp and I'm back to where I started. but whether or not certbot can renew isn't the issue I am having. just laying out some of the troubleshooting that I've done.
:eyes: I see two consecutive slashes :eyes:
[luckily my eyes haven't yet melted - lol]
Hmmm interesting. odd thing is I figured out the issue, and it corrected the double slash.
I ended up going through nginx.conf and commenting out stuff. lo and behold nginx -t succeeded. so then I went and started uncommenting everything that certbot had added one line at a time and testing.
This line was the culprit:
I went and checked that file, sure enough, the path had . switched that out with my domain and now everything works.
Oh, and yeah, I restored the symlinks so certbot isn't broken.
Please show (your current version of) this file:
I have a feeling something may have been changed in there...
Mine (0.31.0) shows this:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AE
S256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-
RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDH
E-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
You were correct, there was an error in this file.
ssl_trusted_certificate /etc/letsencrypt/live/joshcampana.com/fullchain.pem;
was originally
ssl_trusted_certificate /etc/letsencrypt/live/<default>/fullchain.pem;
I mentioned that I fixed it in a roundabout way in a previous comment. But just in case I have something else wrong, here it is:
root@oerlikon:/etc/letsencrypt# cat options-ssl-nginx.conf
# this file.
ssl_session_timeout 10m;
ssl_session_tickets off;
ssl_stapling on;
ssl_stapling_verify on;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
thanks for the help.
Exactly why do you need this again?
The only reference I could find on docs.nginx.com was this:
But it didn't make it clear why.
I mean it sounds like you would use it when trying to trust self-signed certs or certs that aren't found in the trust store.
But that isn't the case with LE certs and chains.
So I'm confused on what benefit it provides.
While according to the current docs, for OCSP to work only a valid intermediate is required in ssl_certificate:
For the OCSP stapling to work, the certificate of the server certificate issuer should be known. If the ssl_certificate file does not contain intermediate certificates, the certificate of the server certificate issuer should be present in the ssl_trusted_certificate file.
However, I think to remember that some time ago an extra ssl option was required for OCSP to work. So might be from that.
Hell if I know. I'm just a dumb welder following a tutorial (i think it was on linuxbabe.com), not a sysadmin getting paid for this :slight_smile:
I think it is safe to remove that line.
I've used OSCP and never had to do anything like that.
Did you finally get things all sorted out?
