Problem renewing, challenge failed
cloud.prsc.org.uk
/root/certbot-auto --apache -d cloud.prsc.org.uk -w /var/www/html/
http-01 challenge for cloud.prsc.org.uk
Waiting for verification…
Challenge failed for domain cloud.prsc.org.uk
    Domain: cloud.prsc.org.uk
    Type: connection
    Detail: Fetching
    http://cloud.prsc.org.uk/.well-known/acme-challenge/_OZuushaj7c-_nCHKM9dpm3gUpZJaqSXG33x-4YPsG4:
My web server is (include version): Apache/2.4.18 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 16.04.6
The version of my client is: 0 .34.0
Been asked to look into renewing the cert for this domain. Getting the above error:
** Timeout during connect (likely firewall problem)**
But ‘ufw status’ returns 'inactive’
Not sure what to try next?
also
root@sun:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
f2b-sshd tcp – anywhere anywhere multiport dports ssh
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain f2b-sshd (1 references)
RETURN all – anywhere anywhere
Hi @funkytwig
your port 80 doesn't answer or isn't confgured ( https://check-your-website.server-daten.de/?q=cloud.prsc.org.uk ):
81.150.182.105 -14 10.033 T
Timeout - The operation has timed out
https://cloud.prsc.org.uk/
81.150.182.105 200 0.800 N
Certificate error: RemoteCertificateChainErrors
http://cloud.prsc.org.uk/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
81.150.182.105 -14 10.026 T
So http-01 validation can't work.
You have a lot of old certificates (first 2017-12-07). Perhaps you have used tls-sni-01 validation via port 443, that's not longer supported.
Is this a home server? So your ISP blocks port 80?
Perhaps check
to use another challenge type.
Thanks for that, so I can do challenge through 443/TLS-ALPN-01 (for now). How do I do this? Not onsite so cant sort 80 today. Or is there another way of doing a challenge with certbot-auto over 443.
Read the doc but cant work out how to set challenge type in certbot-auto
Certbot doesn't support tls-alpn-01. acme.sh does.
