Timeout issue on renewal
Coming back to an old server - over 6 months since last login but it was set to auto-renew (and failed to do so)
  • I am connecting to this server fine without timeouts via terminal, browser, Filezilla, etc
  • I have confirmed DNS A record points to correct ip address
  • I have confirmed port 80 is open
  • I am using ufw with Apache Full ALLOW Anywhere (and v6)
  • I did have ssl redirect enforced (which could(?) result in fail because of out-of-date cert) but I have already retried with redirect removed, same problem
  • have reviewed other answers on similar issues, none have provided anything I can use to progress further
  • short of full LAMP re-install ... ??
My domain is: airinteract.net
I ran this command: certbot --apache -v
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for airinteract.net and www.airinteract.net
http-01 challenge for airinteract.net
http-01 challenge for www.airinteract.net
Challenge failed for domain airinteract.net
Challenge failed for domain www.airinteract.net
Domain: airinteract.net
Type: connection
Detail: 52.91.193.209: Fetching http://airinteract.net/.well-known/acme-challenge/dPuyyNRtpXPFi7ksNGWeCUcC-iU9_H-2s0VuJfg6gJ0: Timeout during connect (likely firewall problem)
Domain: www.airinteract.net
Type: connection
Detail: 52.91.193.209: Fetching http://www.airinteract.net/.well-known/acme-challenge/wtHEcucCoTEW3LSjLwg9XtaTpWT7XABzKl1aSqISLsU: Timeout during connect (likely firewall problem)
Apache/2.4.52
Ubuntu 22.04.4 LTS
AWS
Yes
No
certbot 1.21.0
@NickNalder , welcome to the community!
The connection to the host airinteract.net is timing out:
tumbleweed:~ # curl -s -v 'http://airinteract.net/' > /dev/null
* Host airinteract.net:80 was resolved.
* IPv6: (none)
* IPv4: 52.91.193.209
*   Trying 52.91.193.209:80...
* connect to 52.91.193.209 port 80 from 192.168.1.2 port 56416 failed: Connection timed out
* Failed to connect to airinteract.net port 80 after 132896 ms: Couldn't connect to server
* Closing connection
tumbleweed:~ #
There may be still firewall issue, or the IP address is incorrect.
What does the command curl -s -4 ifconfig.co gives as output?
Hi @bruncsak
I did get a response from ifconfig but was in the process of trying to install a web browser into my ubuntu server terminal environment to read the response when I realised that the problem is likely my AWS security settings (so yes - a firewall, but not one I was thinking about in terms of my on-server setup).
I can access fine from any of my devices, but they are all coming in from my ISP which is probably whitelisted (this was a dev-only site, so I did not want it open to the web as a whole)
I will fix that and am then pretty certain that will resolve the problem
May thanks, will let you know if not!
