Problem renew certificate certbot
Hello I have a problem to renew certificate let’s encrypt with certbot this error is:
~$ sudo /usr/bin/certbot renew --renew-hook "/bin/systemctl reload nginx"
Processing /etc/letsencrypt/renewal/mail.gamesyap.com.conf
Cert not yet due for renewal
Processing /etc/letsencrypt/renewal/gamesyap.com.conf
http-01 challenge for gamesyap.com
http-01 challenge for www.gamesyap.com
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/gamesyap.com.conf produced an unexpected error: Failed authorization procedure. www.gamesyap.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.gamesyap.com/.well-known/acme-challenge/Ufjv7AFXjIgvrpvhiScVAyA6fjYocA_k-9WQIq3zEO8: "
404 Not Found
404 Not Found
". Skipping.
/etc/letsencrypt/live/mail.gamesyap.com/fullchain.pem (skipped)
/etc/letsencrypt/live/gamesyap.com/fullchain.pem (failure)
Hi @onzulin,
It seems that you are using a location directive to specify a direferent root for /.well-known/acme-challenge/ requests so you need to check that the root or alias directive is using the same path as you have it defined in the certbot renewal conf file /etc/letsencrypt/renewal/gamesyap.com.conf.
To test, it, put a test file inside the path to your webroot path and try to get that file with your browser or qith curl if you prefer the command line.
echo -n "This is a test" > /path/to/your/webroot/.well-known/acme-challenge/test
Now try to reach that file with your browser:
http://gamesyap.com/.well-known/acme-challenge/test
or with curl:
curl -ikL http://gamesyap.com/.well-known/acme-challenge/test
Once you can get that file, you should be able to renew your certificate.
You can also check the errors in nginx, them could give you a clue where it is trying to get the challenge and why it is failing.
Cheers,
sahsanu
Thank you for your response, you say that defined certbot reneewal conf file /etc/letsencrypt/renewal/gamesyap.com.conf, I had bad configuration path in the file, I have changed the path on run the command /usr/bin/certbot renew --renew-hook “/bin/systemctl reload nginx” and run wothout errors, thank you very much sahsanu.
Note (IPv6 is at play):
Addresses: 2a01:7e01::f03c:91ff:fe1f:2aa9
139.162.165.192
