Problem on renew certificat
Hello,
I've got a problem this morning when trying to renew my certificat.
The error problem is :
** Verifying 'cert.pem' against 'chain.pem'
ERROR: Unable to validate certificate chain: cert.pem: CN = mail.ipsla.fr
error 20 at 0 depth lookup:unable to get local issuer certificate
Is someone can help me ?
Thanks and Regards
Olivier
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
Thank you for your answer,
Every 90 days I renew some certificat. This morning I've got a problem when I try do deploy the service :
zimbra@yozuri:~/ssl/letsencrypt$ /opt/zimbra/bin/zmcertmgr deploycrt comm cert.pem chain.pem
** Verifying 'cert.pem' against '/opt/zimbra/ssl/zimbra/commercial/commercial.key'
Certificate 'cert.pem' and private key '/opt/zimbra/ssl/zimbra/commercial/commercial.key' match.
I try to renew certificat for 4 domains :
letsencrypt certonly -d mail.ipsla.fr -d smtp.ipsla.fr -d webmail.ipsla.fr -d yozuri.ipslanetwork.net
But the main important is mail.ipsla.fr
My server is running on :
zimbra@yozuri:~/ssl/letsencrypt$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
I think your system software is outdated and doesn't recognize either the current Let's Encrypt intermediate certificates or the root certificate. You should start by checking apt packages are all up to date.
You should check that the file chain.pem is recently updated and not something that's being reused as otherwise it could contain old intermediates.
Based on Installing a StartSSL SSL Certificate with zmcertmgr - Zimbra :: Tech Center it looks like zimbra imports the certificate files into Java keystore. See also Administration Console and CLI Certificate Tools - Zimbra :: Tech Center
I believe letsencrypt was the oldname for certbot and zmcertmgr is the tool used to help configure certs with Zimbra.
I would suggest contacting Zimbra support to get details non exactly what their product is trying to do
