Problem on every activity
Hi
I use acme in a pfsense installation.
Today I have had the necessity to create a certificate for a new domain, after entering the necessary information and clicked on “Issue/Renew” I receive this message
lets-kwan
Renewing certificate
account: SpazioWeb-test
server: letsencrypt-staging
/usr/local/pkg/acme/acme.sh --issue -d ‘www.kwantkdbiella.it’ -d ‘kwantkdbiella.it’ --home ‘/tmp/acme/lets-kwan/’ --accountconf ‘/tmp/acme/lets-kwan/accountconf.conf’ --force --reloadCmd ‘/tmp/acme/lets-kwan/reloadcmd.sh’ --webroot pfSenseacme --log-level 3 --log ‘/tmp/acme/lets-kwan/acme_issuecert.log’
Array
[path] => /etc:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin/
[PATH] => /etc:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin/
[ftpserver] => sftp://web1.kpn.esseweb.intra
[username] => acme
[password] => get8Fg64Dcf94354
[folder] => /webs/esseweb/acme/verifiche
[Tue Sep 24 12:26:20 CEST 2019] Registering account
[Tue Sep 24 12:26:20 CEST 2019] Could not get nonce, let’s try again.
[Tue Sep 24 12:26:23 CEST 2019] Could not get nonce, let’s try again.
[Tue Sep 24 12:26:26 CEST 2019] Could not get nonce, let’s try again.
[Tue Sep 24 12:26:29 CEST 2019] Could not get nonce, let’s try again.
[Tue Sep 24 12:26:31 CEST 2019] Could not get nonce, let’s try again.
[Tue Sep 24 12:26:33 CEST 2019] Registered
[Tue Sep 24 12:26:33 CEST 2019] Can not find account id url.
[Tue Sep 24 12:26:33 CEST 2019] Please check log file for more details: /tmp/acme/lets-kwan/acme_issuecert.log
in the log i see
[Tue Sep 24 12:28:13 CEST 2019] readlink exists=0
[Tue Sep 24 12:28:13 CEST 2019] dirname exists=0
[Tue Sep 24 12:28:13 CEST 2019] Lets find script dir.
[Tue Sep 24 12:28:13 CEST 2019] SCRIPT=’/usr/local/pkg/acme/acme.sh’
[Tue Sep 24 12:28:13 CEST 2019] _script=’/usr/local/pkg/acme/acme.sh’
[Tue Sep 24 12:28:13 CEST 2019] _script_home=’/usr/local/pkg/acme’
[Tue Sep 24 12:28:13 CEST 2019] Using config home:/tmp/acme/lets-kwan/
[Tue Sep 24 12:28:13 CEST 2019] APP
[Tue Sep 24 12:28:13 CEST 2019] 2:LOG_FILE=’/tmp/acme/lets-kwan/acme_issuecert.log’
[Tue Sep 24 12:28:13 CEST 2019] 3:LOG_LEVEL=‘3’
[Tue Sep 24 12:28:13 CEST 2019] LE_WORKING_DIR=’/tmp/acme/lets-kwan/’
[Tue Sep 24 12:28:13 CEST 2019] _main_domain=‘www.kwantkdbiella.it’
[Tue Sep 24 12:28:13 CEST 2019] _alt_domains=‘kwantkdbiella.it’
[Tue Sep 24 12:28:13 CEST 2019] ACME_DIRECTORY=’…’
[Tue Sep 24 12:28:13 CEST 2019] _ACME_SERVER_HOST=‘acme-staging.api.letsencrypt.org’
[Tue Sep 24 12:28:13 CEST 2019] CA_CONF=’/tmp/acme/lets-kwan//ca/acme-staging.api.letsencrypt.org/ca.conf’
[Tue Sep 24 12:28:13 CEST 2019] DOMAIN_PATH=’/tmp/acme/lets-kwan//www.kwantkdbiella.it’
[Tue Sep 24 12:28:13 CEST 2019] ‘pfSenseacme’ does not contain ‘dns’
[Tue Sep 24 12:28:13 CEST 2019] Using ACME_DIRECTORY: …
[Tue Sep 24 12:28:13 CEST 2019] _init api for server: …
[Tue Sep 24 12:28:13 CEST 2019] GET
[Tue Sep 24 12:28:13 CEST 2019] url=’…’
[Tue Sep 24 12:28:13 CEST 2019] timeout=
[Tue Sep 24 12:28:13 CEST 2019] curl exists=0
[Tue Sep 24 12:28:13 CEST 2019] wget exists=127
[Tue Sep 24 12:28:13 CEST 2019] _CURL=‘curl -L --silent --dump-header /tmp/acme/lets-kwan//http.header -g ’
[Tue Sep 24 12:28:13 CEST 2019] ret=‘0’
[Tue Sep 24 12:28:13 CEST 2019] response=’{
“ShnBSmLUXqA”: “…”,
“key-change”: “…”,
“meta”: {
“caaIdentities”: [
“letsencrypt.org”
“terms-of-service”: “…”,
“website”: “…”
“new-authz”: “https://acme-staging.api.letsencrypt.org/acme/new-authz”,
“new-cert”: “https://acme-staging.api.letsencrypt.org/acme/new-cert”,
“new-reg”: “https://acme-staging.api.letsencrypt.org/acme/new-reg”,
“revoke-cert”: “https://acme-staging.api.letsencrypt.org/acme/revoke-cert”
[Tue Sep 24 12:28:13 CEST 2019] ACME_KEY_CHANGE=‘https://acme-staging.api.letsencrypt.org/acme/key-change’
[Tue Sep 24 12:28:13 CEST 2019] ACME_NEW_AUTHZ=‘https://acme-staging.api.letsencrypt.org/acme/new-authz’
[Tue Sep 24 12:28:13 CEST 2019] ACME_NEW_ORDER=‘https://acme-staging.api.letsencrypt.org/acme/new-cert’
[Tue Sep 24 12:28:13 CEST 2019] ACME_NEW_ACCOUNT=‘https://acme-staging.api.letsencrypt.org/acme/new-reg’
[Tue Sep 24 12:28:13 CEST 2019] ACME_REVOKE_CERT=‘https://acme-staging.api.letsencrypt.org/acme/revoke-cert’
[Tue Sep 24 12:28:13 CEST 2019] ACME_AGREEMENT=‘https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf’
[Tue Sep 24 12:28:13 CEST 2019] ACME_NEW_NONCE
[Tue Sep 24 12:28:13 CEST 2019] ACME_VERSION
[Tue Sep 24 12:28:13 CEST 2019] Le_NextRenewTime
[Tue Sep 24 12:28:13 CEST 2019] OK
[Tue Sep 24 12:28:13 CEST 2019] 2:Le_Domain=‘www.kwantkdbiella.it’
[Tue Sep 24 12:28:13 CEST 2019] 3:Le_Alt=‘kwantkdbiella.it’
[Tue Sep 24 12:28:14 CEST 2019] 4:Le_Webroot=‘pfSenseacme’
[Tue Sep 24 12:28:14 CEST 2019] OK
[Tue Sep 24 12:28:14 CEST 2019] 5:Le_PreHook=’’
[Tue Sep 24 12:28:14 CEST 2019] 6:Le_PostHook=’’
[Tue Sep 24 12:28:14 CEST 2019] 7:Le_RenewHook=’’
[Tue Sep 24 12:28:14 CEST 2019] 8:Le_API=‘https://acme-staging.api.letsencrypt.org/directory’
[Tue Sep 24 12:28:14 CEST 2019] _on_before_issue
[Tue Sep 24 12:28:14 CEST 2019] _chk_main_domain=‘www.kwantkdbiella.it’
[Tue Sep 24 12:28:14 CEST 2019] _chk_alt_domains=‘kwantkdbiella.it’
[Tue Sep 24 12:28:14 CEST 2019] ‘pfSenseacme’ does not contain ‘no’
[Tue Sep 24 12:28:14 CEST 2019] Le_LocalAddress
[Tue Sep 24 12:28:14 CEST 2019] d=‘www.kwantkdbiella.it’
[Tue Sep 24 12:28:14 CEST 2019] Check for domain=‘www.kwantkdbiella.it’
[Tue Sep 24 12:28:14 CEST 2019] _currentRoot=‘pfSenseacme’
[Tue Sep 24 12:28:14 CEST 2019] d=‘kwantkdbiella.it’
[Tue Sep 24 12:28:14 CEST 2019] Check for domain=‘kwantkdbiella.it’
[Tue Sep 24 12:28:14 CEST 2019] ‘pfSenseacme’ does not contain ‘apache’
[Tue Sep 24 12:28:14 CEST 2019] config file is empty, can not read CA_KEY_HASH
[Tue Sep 24 12:28:14 CEST 2019] _saved_account_key_hash
[Tue Sep 24 12:28:14 CEST 2019] Using config home:/tmp/acme/lets-kwan/
[Tue Sep 24 12:28:14 CEST 2019] ACME_DIRECTORY=‘https://acme-staging.api.letsencrypt.org/directory’
[Tue Sep 24 12:28:14 CEST 2019] _ACME_SERVER_HOST=‘acme-staging.api.letsencrypt.org’
[Tue Sep 24 12:28:14 CEST 2019] CA_CONF=’/tmp/acme/lets-kwan//ca/acme-staging.api.letsencrypt.org/ca.conf’
[Tue Sep 24 12:28:14 CEST 2019] _regAccount
[Tue Sep 24 12:28:14 CEST 2019] _init api for server: https://acme-staging.api.letsencrypt.org/directory
[Tue Sep 24 12:28:14 CEST 2019] RSA key
[Tue Sep 24 12:28:14 CEST 2019] pub_exp=‘010001’
[Tue Sep 24 12:28:14 CEST 2019] [Tue Sep 24 12:28:14 CEST 2019] base64 single line.xxd exists=127
[Tue Sep 24 12:28:14 CEST 2019] URGLY_PRINTF=‘1’
[Tue Sep 24 12:28:14 CEST 2019] e=‘AQAB’
[Tue Sep 24 12:28:14 CEST 2019] modulus=‘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’
[Tue Sep 24 12:28:14 CEST 2019] xxd exists=127[Tue Sep 24 12:28:14 CEST 2019]
base64 single line.
[Tue Sep 24 12:28:14 CEST 2019] n='xGU_fZNtmXe42ph15SyRCjyNIz7NRboiLoouUQ_JHbNIfMb4vweL_IktK_WqCShoWofxhSpdlzsPFLndOMQe_YL-bAN8BB2TafOuNc8p41w0CCGIh8qXLuI1wTYhrTSj0u60rUTjBR-cNP1rVpPZtNQbjq5XefW98gGzlRmrPgoimBy6k9WwvxMmgcgUn6yWw-aVO7n3ivbuhbYDfVfenE5PhKZmKpSXfzFRo-BmfsTl1zp9n3e0Rz6zGIHURaABOE6qcBLo_ipd0ovTqdpCugxoTvqpP4H_1rcCszCHY9Byms897fvYAffdWzRfaRxA-rK4EQG87KKvUQhoDZckKePkPZ8G9LaLLQbnpfDeehcELa_7GSpY2aF_P1fHnsOz_7LH3qK_HsM-MGTEBXT5Xl9m7Xb_Aua8tO1lSH2RozpyPhtFgQNbxjRxRbpfSEPB5VrANePm30uXjxsgJ6pYrTpOQcKiEnicykG5JGYFseGeiUDJs8212Ak18_dG6k-PUt81fzbGglsWT7nHu8baIKqhY0XpfiLgOylW1m1Qi0D4LLpd1sZrbOA5-G-HeMn1Ru1iDG6xvyg6wCdSNNrgGNKTqJrL73uDf9eCHuOKn697UQKbp2gD4
-WdcfpBhLbhjvOm4n9uaA7BZrGWy-OA6pl8w6GAqXH5xB8ubabWSU’
[Tue Sep 24 12:28:14 CEST 2019] jwk=’{“e”: “AQAB”, “kty”: “RSA”, “n”: "xGU_fZNtmXe42ph15SyRCjyNIz7NRboiLoouUQ_JHbNIfMb4vweL_IktK_WqCShoWofxhSpdlzsPFLndOMQe_YL-bAN8BB2TafOuNc8p41w0CCGIh8qXLuI1wTYhrTSj0u60rUTjBR-cNP1rVpPZtNQbjq5XefW98gGzlRmrPgoimBy6k9WwvxMmgcgUn6yWw-aVO7n3ivbuhbYDfVfenE5PhKZmKpSXfzFRo-BmfsTl1zp9n3e0Rz6zGIHURaABOE6qcBLo_ipd0ovTqdpCugxoTvqpP4H_1rcCszCHY9Byms897fvYAffdWzRfaRxA-rK4EQG87KKvUQhoDZckKePkPZ8G9LaLLQbnpfDeehcELa_7GSpY2aF_P1fHnsOz_7LH3qK_HsM-MGTEBXT5Xl9m7Xb_Aua8tO1lSH2RozpyPhtFgQNbxjRxRbpfSEPB5VrANePm30uXjxsgJ6pYrTpOQcKiEnicykG5JGYFseGeiUDJs8212Ak18_dG6k-PUt81fzbGglsWT7nHu8baIKqhY0XpfiLgOylW1m1Qi0D4LLpd1sZrbOA5-G-HeMn1Ru1iDG6xvyg6wCdSNNrgGNKTqJrL73uDf9eCHuOKn697UQKbp2gD4
-WdcfpBhLbhjvOm4n9uaA7BZrGWy-OA6pl8w6GAqXH5xB8ubabWSU"}’
[Tue Sep 24 12:28:14 CEST 2019] JWK_HEADER=’{“alg”: “RS256”, “jwk”: {“e”: “AQAB”, “kty”: “RSA”, “n”: “xGU_fZNtmXe42ph15SyRCjyNIz7NRboiLoouUQ_JHbNIfMb4vweL_IktK_WqCShoWofxhSpdlzsPFLndOMQe_YL-bAN8BB2TafOuNc8p41w0CCGIh8qXLuI1wTYhrTSj0u60rUTjBR-cNP1rVpPZtNQbjq5XefW98gGzlRmrPgoimBy6k9WwvxMmgcgUn6yWw-aVO7n3ivbuhbYDfVfenE5PhKZmKpSXfzFRo-BmfsTl1zp9n3e0Rz6zGIHURaABOE6qcBLo_ipd0ovTqdpCugxoTvqpP4H_1rcCszCHY9Byms897fvYAffdWzRfaRxA-rK4EQG87KKvUQhoDZckKePkPZ8G9LaLLQbnpfDeehcELa_7GSpY2aF_P1fHnsOz_7LH3qK_HsM-MGTEBXT5Xl9m7Xb_Aua8tO1lSH2RozpyPhtFgQNbxjRxRbpfSEPB5VrANePm30uXjxsgJ6pYrTpOQcKiEnicykG5JGYFseGeiUDJs8212Ak18_dG6k-PUt81fzbGglsWT7nHu8baIKqhY0XpfiLgOylW1m1Qi0D4LLpd1sZrbOA5-G-HeMn1Ru1iDG6xvyg6wCdSNNrgGNKTqJrL73uDf9eCHuOKn697UQKbp2gD4_-WdcfpBhLbhjvOm4n9uaA7BZrGWy-OA6pl8w6GAqXH5xB8ubabWSU”}}’
[Tue Sep 24 12:28:14 CEST 2019] Registering account
[Tue Sep 24 12:28:14 CEST 2019] url=‘https://acme-staging.api.letsencrypt.org/acme/new-reg’
[Tue Sep 24 12:28:14 CEST 2019] payload=’{“resource”: “new-reg”, “terms-of-service-agreed”: true, “agreement”: “https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf”}’
[Tue Sep 24 12:28:14 CEST 2019] Use cached jwk for file: /tmp/acme/lets-kwan//ca/acme-staging.api.letsencrypt.org/account.key
[Tue Sep 24 12:28:14 CEST 2019] payload64=‘eyJyZXNvdXJjZSI6ICJuZXctcmVnIiwgInRlcm1zLW9mLXNlcnZpY2UtYWdyZWVkIjogdHJ1ZSwgImFncmVlbWVudCI6ICJodHRwczovL2xldHNlbmNyeXB0Lm9yZy9kb2N1bWVudHMvTEUtU0EtdjEuMi1Ob3ZlbWJlci0xNS0yMDE3LnBkZiJ9’
[Tue Sep 24 12:28:14 CEST 2019] _request_retry_times=‘1’
[Tue Sep 24 12:28:14 CEST 2019] Get nonce. ACME_DIRECTORY=‘https://acme-staging.api.letsencrypt.org/directory’
[Tue Sep 24 12:28:14 CEST 2019] GET
[Tue Sep 24 12:28:14 CEST 2019] url=‘https://acme-staging.api.letsencrypt.org/directory’
[Tue Sep 24 12:28:14 CEST 2019] timeout=
[Tue Sep 24 12:28:14 CEST 2019] curl exists=0
[Tue Sep 24 12:28:14 CEST 2019] wget exists=127
[Tue Sep 24 12:28:14 CEST 2019] _CURL='curl -L --silent --dump-header /tmp/acme/lets-kwan//http.header -g ’
[Tue Sep 24 12:28:15 CEST 2019] ret=‘0’
[Tue Sep 24 12:28:15 CEST 2019] _headers='HTTP/2 200
server: nginx
date: Tue, 24 Sep 2019 10:28:15 GMT
content-type: application/json
content-length: 704
cache-control: public, max-age=0, no-cache
replay-nonce: 0002r9BpI6VET6PWYSwQ2Yo6WZnCL12OYSb0LLHOzjfVYvc
x-frame-options: DENY
strict-transport-security: max-age=604800
[Tue Sep 24 12:28:26 CEST 2019] _CACHED_NONCE
[Tue Sep 24 12:28:26 CEST 2019] nonce
[Tue Sep 24 12:28:26 CEST 2019] Could not get nonce, let’s try again.
[Tue Sep 24 12:28:28 CEST 2019] Registered
[Tue Sep 24 12:28:28 CEST 2019] responseHeaders
[Tue Sep 24 12:28:28 CEST 2019] _accUri
[Tue Sep 24 12:28:28 CEST 2019] Can not find account id url.
[Tue Sep 24 12:28:28 CEST 2019] _on_issue_err
[Tue Sep 24 12:28:28 CEST 2019] Please check log file for more details: /tmp/acme/lets-kwan/acme_issuecert.log
[Tue Sep 24 12:28:28 CEST 2019] _chk_vlist
Then I tried to renew a different certificate and to register a new account, but the answer was the same
What can i do? What’s wrong?
Best Regards
What version of acme.sh?
The acme.sh as at the 2.7.9 version
I don’t know if it will help, but I’d suggest upgrading to the latest version, and trying the acme-staging-v02 environment.
Hmmm, I had thought of this too, but first I need to update the pfsense.
I think I’ll have to go in this direction to see if it resolves
Thanks
This night I’ve updated my pfsense installation and the acme package and now all is fine
Thanks for the support
