Hi, I got the email “Action required: Let’s Encrypt certificate renewals” and attempted to follow this guide: How to stop using TLS-SNI-01 with Certbot.
“If the version is less than 0.28, you need to upgrade your Certbot. Visit…”
Here I ran the commands
$ sudo apt-get update
$ sudo apt-get install software-properties-common
$ sudo add-apt-repository universe
$ sudo add-apt-repository ppa:certbot/certbot
$ sudo apt-get install certbot python-certbot-apache
I stopped at the Get started section since I had a certificate.
$ certbot --version
certbot 0.28.0
Then I ran the recommended
$ sudo sh -c "sed -i.bak -e 's/^\(pref_challs.*\)tls-sni-01\(.*\)/\1http-01\2/g' /etc/letsencrypt/renewal/*; rm -f /etc/letsencrypt/renewal/*.bak"
And got
$ sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/naturalhazardsgroup.com.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for naturalhazardsgroup.com
http-01 challenge for www.naturalhazardsgroup.com
Attempting to renew cert (naturalhazardsgroup.com) from /etc/letsencrypt/renewal/naturalhazardsgroup.com.conf produced an unexpected error: Failed authorization procedure. naturalhazardsgroup.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://naturalhazardsgroup.com/.well-known/acme-challenge/3u-7Rn_H9vH1LxBBb0X5f_7BzmXykWwFGmzEJ2wv05g: "\n\n\n<!DOCTYPE html>\n\n<html class=\"no-js\" lang=\"en-US\">\n\n<head>\n \n<meta charset=\"UTF-8\">\n<meta name=\"viewport\" content=\"width=dev". Skipping.
Processing /etc/letsencrypt/renewal/new.naturalhazardsgroup.com.conf
http-01 challenge for new.naturalhazardsgroup.com
Attempting to renew cert (new.naturalhazardsgroup.com) from /etc/letsencrypt/renewal/new.naturalhazardsgroup.com.conf produced an unexpected error: Failed authorization procedure. new.naturalhazardsgroup.com (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for new.naturalhazardsgroup.com. Skipping.
/etc/letsencrypt/live/naturalhazardsgroup.com/fullchain.pem (failure)
/etc/letsencrypt/live/new.naturalhazardsgroup.com/fullchain.pem (failure)
2 renew failure(s), 0 parse failure(s)
Domain: naturalhazardsgroup.com
Detail: Invalid response from
Domain: new.naturalhazardsgroup.com
Type: None
Detail: DNS problem: NXDOMAIN looking up A for
There used to be a site at new.naturalhazardsgroup.com and a DNS record, this was removed at some point. I tried to clean it up maybe foolishly
$ sudo rm -r etc/letsencrypt/archive/new.naturalhazardsgroup.com
$ sudo rm -r /etc/letsencrypt/live/new.naturalhazardsgroup.com/
$ sudo rm -r /etc/letsencrypt/renewal/new.naturalhazardsgroup.com.conf
I have the remaining error:
_[removed - says I am not allowed to post more than 20 links on forum]_
http://naturalhazardsgroup.com/.well-known/acme-challenge/OnwYyDAMFKUg3v15FvFVwPxkAMJHxMIjmj70eIG_X1k:
My web server is: Apache/2.4.18
The operating system my web server runs on is: Ubuntu 16.04
My hosting provider is: DigitalOcean
I’m using a control panel to manage my site: no
The version of my client is: certbot 0.28.0
