i am trying to install LE on my gandi.net vps server and when i run
certbot --apache
This is what i get:
No vhost exists with servername or alias of: www.mysite.it (or it’s in a file with multiple vhosts, which Certbot can’t parse yet). No vhost was selected. Please specify ServerName or ServerAlias in the Apache config, or split vhosts into separate files.
Falling back to default vhost *:443…
Waiting for verification…
Failed authorization procedure. www.mysite.it (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Error getting validation data
Now.
I have spent some time looking around here to find a solution, i found a few people with similar problem but none of the solution suggested worked out.
As far as my knowledge goes(not much) it seems to be that multiple vhosts are defined in the conf file. I have seen suggestion about splitting vhosts in multiple files etcc… but. It seems that i have no vhosts defined at all.
When i run
apachectl -S
to check the vhosts configuration, here is what i got:
[root@server01 ~]# apachectl -S
VirtualHost configuration:
ServerRoot: "/etc/httpd"
Main DocumentRoot: “/var/www/html"
Main ErrorLog: “/etc/httpd/logs/error_log"
Mutex proxy: using_defaults
Mutex authn-socache: using_defaults
Mutex default: dir=”/run/httpd/” mechanism=default
Mutex authdigest-opaque: using_defaults
Mutex proxy-balancer-shm: using_defaults
Mutex authdigest-client: using_defaults
PidFile: "/run/httpd/httpd.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“apache” id=48
Group: name=“apache” id=48
[root@server01 ~]#
Not really sure about what to do next. I have a conf file at /etc/httpd/conf/httpd.conf and no ssl.conf i can find, if thats anything that matter.
Anyone a bit more experienced can help me out to get LE installed and to get me to enjoy the https:// on my site?
Thanks in advance
