Problem installing certificate - apache2ctl graceful
Hello. I have got a VPS server with Apache2 on Debian. I wanted to install lets encrypt certificate, so I have done so far:
log in to SSH
saved "deb http://ftp.debian.org/debian jessie-backports main" into /etc/apt/sources.list
Run apt-get update
No error so far
than entered: "sudo apt-get install python-certbot-apache -t jessie-backports"
No error so far
And last I’ve entered this : " sudo certbot --apache "
And I have got this:
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel):domain.com
Enter email address (used for urgent renewal and security notices) (Enter ‘c’ to
cancel):mail@domain.com
agree in order to register with the ACME server at
https://acme-v01.api.letsencrypt.org/directory
(A)gree/©ancel: A
tls-sni-01 challenge for domain.com
Enabled Apache socache_shmcb module
Enabled Apache ssl module
/usr/lib/python2.7/dist-packages/OpenSSL/rand.py:58: UserWarning: implicit cast from ‘char *’ to a different pointer type: will be forbidden in the future (check that the types are as you expect; use an explicit ffi.cast() if they are correct)
result_code = _lib.RAND_bytes(result_buffer, num_bytes)
Error while running apache2ctl graceful.
httpd not running, trying to start
Action ‘graceful’ failed.
AH00112: Warning: DocumentRoot [/var/lib/letsencrypt/tls_sni_01_page/] does not exist
(98)Address already in use: AH00073: make_sock: unable to listen for connections on address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Encountered exception during recovery
File “/usr/lib/python2.7/dist-packages/certbot/error_handler.py”, line 99, in _call_registered
self.funcs-1
File “/usr/lib/python2.7/dist-packages/certbot/auth_handler.py”, line 280, in _cleanup_challenges
self.auth.cleanup(achalls)
File “/usr/lib/python2.7/dist-packages/certbot_apache/configurator.py”, line 1769, in cleanup
self.restart()
File “/usr/lib/python2.7/dist-packages/certbot_apache/configurator.py”, line 1658, in restart
self._reload()
File “/usr/lib/python2.7/dist-packages/certbot_apache/configurator.py”, line 1669, in _reload
raise errors.MisconfigurationError(str(err))
MisconfigurationError: Error while running apache2ctl graceful.
Am I missing anything here?
Could you please show the output of the command:
sudo netstat --tcp -lpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1043/httpd
tcp 0 0 0.0.0.0:993 0.0.0.0:* LISTEN 247/dovecot
tcp 0 0 0.0.0.0:995 0.0.0.0:* LISTEN 247/dovecot
tcp 0 0 0.0.0.0:587 0.0.0.0:* LISTEN 241/exim
tcp 0 0 127.0.0.1:3310 0.0.0.0:* LISTEN 279/clamd
tcp 0 0 0.0.0.0:110 0.0.0.0:* LISTEN 247/dovecot
tcp 0 0 127.0.0.1:783 0.0.0.0:* LISTEN 2270/spamd.pid -d -
tcp 0 0 0.0.0.0:143 0.0.0.0:* LISTEN 247/dovecot
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1043/httpd
tcp 0 0 0.0.0.0:59184 0.0.0.0:* LISTEN 232/sshd
tcp 0 0 0.0.0.0:465 0.0.0.0:* LISTEN 241/exim
tcp 0 0 78.46.31.21:53 0.0.0.0:* LISTEN 1211/named
tcp 0 0 127.0.0.2:53 0.0.0.0:* LISTEN 1211/named
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 1211/named
tcp 0 0 127.0.0.1:953 0.0.0.0:* LISTEN 1211/named
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 241/exim
tcp6 0 0 :::3306 :::* LISTEN 756/mysqld
tcp6 0 0 :::587 :::* LISTEN 241/exim
tcp6 0 0 :::2222 :::* LISTEN 3968/directadmin
tcp6 0 0 :::59184 :::* LISTEN 232/sshd
tcp6 0 0 :::465 :::* LISTEN 241/exim
tcp6 0 0 :::53 :::* LISTEN 1211/named
tcp6 0 0 :::21 :::* LISTEN 1122/proftpd: (acce
tcp6 0 0 ::1:953 :::* LISTEN 1211/named
tcp6 0 0 :::25 :::* LISTEN 241/exim
OK, httpd listens on ports 80 and 443.
What is the output if you just invoke apache2ctl graceful now?
After I’ve input apache2ctl graceful I get the results:
Hmm, there seems to be something misconfigured. Maybe Apache runs but the service script does not find the pidfile for some reason?
You could try the following:
$ sudo killall httpd
This will stop all running instances of Apache.
Then try to start the service again:
$ sudo apache2ctl start
If this succeeds, just try to graceful reload it afterwards, when this works get back to certbot.
OK, so I’ve entered sudo killall httpd and it works ( I mean there was no error )
Than I’ve entered sudo apache2ctl start and it also works ( no error )
Than I’ve entered apache2ctl graceful and also no errors ( so your advice worked )
I did not yet try certbot, cause now my website do not work ( when I enter my site name in the browser I get Apache2 Debian Default Page ). Can I fix it?
I wonder how it could work at all beforehand.
Have a look into /etc/apache2/sites-available and /etc/apache2/sites-enabled.
Are there any files?
In the first one are 000-default.conf and default-ssl.conf
in the second one is 000-default.conf
What about the command (please replace your domain in it):
$ sudo grep -r domain /etc/apache2
so I should type sudo grep -r domain.com /etc/apache2
by domain.com I mean my real domain name, right?
OK. I’ve correct it. I needed to change 000-default.conf to point to my website folders.
I did run certbot, and I again needed to change 000-default.conf to point to my domain folder.
So I’ve got Congratulations message. I went to https://www.ssllabs.com/ssltest/analyze.html?d= to analyze my domain. I did score Overall Rating A. But if I go to my website by https://domain.com I get ERR_SSL_SERVER_CERT_BAD_FORMAT in Google Chrome.
Hello again. Now, when I want to verify my address using https://www.ssllabs.com/ssltest/analyze.html?d=2 it is showing me:
Certificate name mismatch
and
Try these other domain names (extracted from the certificates):
localhost
What can I do now?
