Problem install SSL
My domain is:unifi.dpntec.net.br
I ran this command: # letsencrypt certonly
1: Apache Web Server plugin (apache)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press ‘c’ to cancel): 2
Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’
to cancel): unifi.dpntec.net.br
http-01 challenge for unifi.dpntec.net.br
Waiting for verification…
Failed authorization procedure. unifi.dpntec.net.br (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://unifi.dpntec.net.br/.well-known/acme-challenge/LaotSPJcsXiA95DYuyzFBIonDHxGHLjbEqh-DtQifHQ: Timeout during connect (likely firewall problem)
    Domain: unifi.dpntec.net.br
    Type: connection
    Detail: Fetching
My web server is (include version): apache2 - 2.4.29-1ubuntu4.10
The operating system my web server runs on is (include version): 18.04.1-Ubuntu
My hosting provider, if applicable, is: Azure
I can login to a root shell on my machine (yes or no, or I don’t know): Yes, root
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot --version certbot 0.31.0 or certbot-auto --version certbot 0.38.0
Hi @fhverga
checking your domain there is no older certificate, so it's your first certificate - https://check-your-website.server-daten.de/?q=unifi.dpntec.net.br
But --standalone is hard to debug.
Your port 80 must be open. Port 443 is open, port 80 not.
• http://unifi.dpntec.net.br/
13.90.82.58 -14 10.027 T
Timeout - The operation has timed out
• https://unifi.dpntec.net.br/
13.90.82.58 302 https://unifi.dpntec.net.br/manage 2.674 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
• https://unifi.dpntec.net.br/manage 302 https://unifi.dpntec.net.br/manage/account/login?redirect=%2Fmanage 2.490 N
• https://unifi.dpntec.net.br/manage/account/login?redirect=%2Fmanage
No GZip used - 3779 / 12957 - 29,17 % possible 200 Html is minified: 102,00 % 2.530 N
• http://unifi.dpntec.net.br/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
May be a not running webserver, may be a firewall or a wrong configured port forwarding.
Isn't there a http webserver (port 80), so you can use --apache or --webroot?
