Problem certificate NGINX ARM Debian
Hi, I need a help from you.
I explain my configuration
  1. I use a Debian server on ARM architetture.
  2. I installed NGINX web server and work fine.
  3. for now I don’t have enable any firewall system.
  4. My isp does not allow me to open the port 80, so I could open the 8080 and 443 ports and correctly configured and tested the nginx operation.
  5. I have configured a dynamic DNS with the ddclient software, example: mywebsite.dyndns.com
  6. I created 2 CNAME record example:
    mywebsite.mydomain.com >> mywebsite.dyndns.com
    www.mywebsite.mydomain.com >> mywebsite.dyndns.com
  7. controlled via browser both the http and https connections and everything is working
Now the problem:
I try to create a certificate for: mywebsite.mydomain.com and www.mywebsite.mydomain.com but without success.
I try to use this command:
certbot --authenticator standalone --installer nginx --http-01-port 8080 --tls-sni-01-port 443 -d mywebsite.mydomain.com -d www.mywebsite.mydomain.com --pre-hook “service nginx stop” --post-hook “service nginx start”
But don’t work:
Running pre-hook command: service nginx stop
http-01 challenge for mywebsite.mydomain.com
http-01 challenge for www.mywebsite.mydomain.com
Waiting for verification…
Running post-hook command: service nginx start
Failed authorization procedure. mywebsite.mydomain.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://mywebsite.mydomain.com/.well-known/acme-challenge/j7uhKmDTsUFUGe58tfhM9Ctge0gi9T6nr5FXYiIaevw: Timeout during connect (likely firewall problem)
    Domain: mywebsite.mydomain.com
    Type: connection
    Detail: Fetching
Thanks
You’ll need to use DNS-01 validation since http-01 only connect to port 80 first.
Thank you
i tr to read a manual od certbt, And I undestan i must to open a port 53 on the router.
This is not possible from my ISP
I'm not a expert can you give me same command example or alternative?
You won’t need to add that to your router. Instead you would add the validation records to the dyndns…
Thank you
Thanks, but I resolved, I installed miniupnpc on debian server. And every think are ok now.
Regards
