Problem binding to port 80: [WinError 10013] An attempt was made to access a socket in a way forbidden by its access permissions
My domain is:https://portal.slicoinsurance.com
I ran this command: certbot certonly --standalone -d slicoinsurance.com --staple-ocsp -m info@slicoinsurance.com --agree-tos
It produced this output: Saving debug log to C:\Certbot\log\letsencrypt.log
Requesting a certificate for slicoinsurance.com
missions
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.lo
g or re-run Certbot with -v for more details.
My web server is (include version): windows server 2019
I know port80 is in use. when i do stop or kill the PID using it and re-run the certbot i get
Certbot failed to authenticate some domains (authenticator: standalone). The Certificate Authority reported these proble
ms:
Domain: slicoinsurance.com
Detail: Invalid response from http://slicoinsurance.com/.well-known/acme-challenge/QgmoN1hGV9SuPWvH1pwc69uNtSPy5GHAi-A
TcJ-RPnU [23.236.62.147]: 404
Hint: The Certificate Authority failed to download the challenge files from the temporary standalone webserver started b
y Certbot on port 80. Ensure that the listed domains point to this machine and that it can accept inbound connections fr
om the internet.
slicoinsurance.com currently points to a Wix website.
It needs to point to your Windows server before you're going to be able to issue a certificate using Certbot.
how do i issue wildcard cert for it?
i have
2 subdomains that all need ssl cert
By Let's Encrypt policy, wildcard certificates are treated specially and can only be obtained using the DNS-01 method.
That method requires creating (new) DNS TXT records in your DNS zone as requested by the certificate authority, typically every time the wildcard certificate is going to be renewed.
I don't think your current DNS provider (wixdns) supports an API integration that could allow software like Certbot to do this automatically; however, I might be wrong, and other DNS providers do support this.
If you want to keep your DNS hosted at wixdns, I would suggest asking them about API support, or searching this forum to see if anyone else has made that work.
Wildcard will not work so am looking to generate a cert for each subdomain.
but am getting the same error.
certbot certonly --standalone -d portal.slicoinsurance.com --staple-ocsp -m info@slicoinsurance.com --agree-tos
Requesting a certificate for portal.slicoinsurance.com
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
world wide services is currenting running on that port.
Is your account an administrative account?
yes it is
i cant stop world wide services but i get
Domain: portal.slicoinsurance.com
Type: connection
Detail: Fetching http://portal.slicoinsurance.com/.well-known/acme-challenge/IatGmiWmZHxVGmZE56zUboRw70IoFieQtqsQDtsiKKQ: Timeout during connect (likely firewall problem)
You may want to consider an ACME client designed for Windows. Certify The Web is a popular one with a gui and is especially good with IIS server on Windows. It is on the recommended list by Let's Encrypt for Windows.
The author is a regular helper here and does very good with support at their own website too.
thanks i'll try it now
i have tried it with i get Certify The Web
Validation of the required challenges did not complete successfully. Domain validation failed: www.portal.slicoinsurance.com
DNS problem: NXDOMAIN looking up A for www.portal.slicoinsurance.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.portal.slicoinsurance.com - check that a DNS record exists for this domain BadRequest urn:ietf:params:acme:error:dns
Did you add www yourself?
It's a different domain from the non-www one. (I had doubts)
no i didnt
Ok, then you should check the documentation for Certify and how to tell it what domain names you actually want. (I don't know that software)
Or just add a DNS entry for www.portal the same as you did for just portal
