Problem binding to port 80: Could not bind to IPv4 or IPv6
adamos-price-calculator.softwareag.com
certbot renew
Processing C:\Certbot\renewal\adamos-price-calculator.softwareag.com.conf
http-01 challenge for adamos-price-calculator.softwareag.com
e[31mAttempting to renew cert (adamos-price-calculator.softwareag.com) from C:\Certbot\renewal\adamos-price-calculator.softwareag.com.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6.. Skipping.e[0m
e[31mAll renewal attempts failed. The following certs could not be renewed:e[0m
e[31m C:\Certbot\live\adamos-price-calculator.softwareag.com\fullchain.pem (failure)e[0m
e[31m1 renew failure(s), 0 parse failure(s)e[0m
Apache tomcat 8.5
Windows 2009 Server
no
1.8.0
Hello all,
You see the information provided. The problem is, that no matter that the tomcat is stopped, still this issue appears, which should appear, when port 80 is running. I executed the following command:
netstat -aon | findstr 80 and i see, that the port 80 is still used:
:\Users\y509110>netstat -aon | findstr 80
TCP 0.0.0.0:80 0.0.0.0:0 LISTENING 4
TCP 0.0.0.0:49665 0.0.0.0:0 LISTENING 1280
TCP 193.26.198.18:51907 2.16.186.11:80 TIME_WAIT 0
TCP [::]:80 [::]:0 LISTENING 4
TCP [::]:49665 [::]:0 LISTENING 1280
and i was wondering whether another port could be specified to generate the certificates?
The authenticator is standalone.
Hi @Ivaylo.Iliev
there answers an IIS, not an Apache.
D:\temp>download http://adamos-price-calculator.softwareag.com/ -h
Error (1): Der Remoteserver hat einen Fehler zurückgegeben: (404) Nicht gefunden.
ProtocolError
Content-Length: 0
Date: Thu, 15 Apr 2021 13:18:11 GMT
Server: Microsoft-IIS/10.0
Status: 404 NotFound
404
No, port 80 is required, may be with a redirect to domain name + port 443.
If you already have a web server running, you probably want to use a certbot plugin that integrates with it, rather than using the standalone plugin. The standalone plugin is designed for when there isn't a web server so it will start a mini-server up for you for answering the challenge, but as you see it can't run if there's already a web server running on the server.
Hi Jurgen,
Thank you for your response and your cooperation.
The site is available under:
https://adamos-price-calculator.softwareag.com/pc/
Best,
Ivaylo
That's unrelevant. Please read the basics:
and
Your port 80 is checked, nothing else.
If there runs something else, that will fail -> your configuration is wrong.
Hello Peter,
Yes, you are absolutely correct, but i am not sure what i have to do in order to use the webserver and certbot simultaneously? I read about the different options - another option is "apache" as described here-
User Guide — Certbot 1.11.0.dev0 documentation (eff.org)
should i use it?
These are the renewals params in the C:\Certbot\renewal\adamos-price-calculator.softwareag.com.conf:
[renewalparams]
account = <some_account_info_here>
authenticator = standalone
Also my problem was, that no matter that i stopped the apache server, the certificates did not renew.
