It produced this output: Problem binding to port 443: Could not bind to IPv4 or IPv6
My web server is (include version): Sentora
The operating system my web server runs on is (include version): Ubuntu 14.04.5 LTS
My hosting provider, if applicable, is: DreamHost Cloud
Has something changed how letsencrypt processes cert updates in the last couple of months? I have four domains using SSL. Three were renewed fine a couple of months ago, but when I ran the renew command today the "Problem binding to port 443: Could not bind to IPv4 or IPv6
" error message appeared for admin.rstunlimited.us/.
letsencrypt-auto and certbot-auto both run the same script which autoupdates the software release. Thus if you run letsencrypt-auto --version and certbot-auto --version, you should see the same software version!
However, using the name letsencrypt-auto is often a sign of following old documentation and might mean that it would be a good idea to consult newer documentation.
I agree with @stevenzhu that it would be useful to see the log (at the very least, the full output from running the command).
My guess is that the
comes from a certificate that was obtained using --standalone. Perhaps when the certificate was obtained, there was no web server running on port 443 (and so --standalone could bind it), but now there is one. Normally --standalone is meant for use when you don't have an existing web server at all, or when you have a web server that you can shut down temporarily during issuance and renewal.
