Problem after revoking certificate in order to activate new domain
My domain is: christinevilella.tk (old one which I have revoked successfully)
christinevilella.ml (the new one which I have an issue to request certificate)
I ran this command: ./certbot-auto --apache -d christineonline.ml
http-01 challenge for christineonline.ml
Waiting for verification…
Challenge failed for domain christineonline.ml
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Raspbian 4.19.66-v7+ on RPI 2B
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): cerbot 1.4.0
Dear community,
I have an issue after having revoke previous domain certificate for christinevilella.tk
Command used to revoke : ./certbot-auto revoke --domain christineonline.tk --cert-path /etc/letsencrypt/live/christineonline.tk/cert.pem --key-path /etc/letsencrypt/live/christineonline.tk/privkey.pem
Output :
Upgrading certbot-auto 1.3.0 to 1.4.0…
Replacing certbot-auto…
Creating virtual environment…
Installing Python packages…
Installation succeeded.
Would you like to delete the cert(s) you just revoked, along with all earlier
and later versions of the cert?
(Y)es (recommended)/(N)o: Y
Deleted all files relating to certificate christineonline.tk.
Congratulations! You have successfully revoked the certificate that was located
at /etc/letsencrypt/live/christineonline.tk/cert.pem
Now, I would like to activate new domain christineonline.ml with this command : ./certbot-auto --apache -d christineonline.ml
OUTPUT
It sounds like my webserver don’t respond.
I have 2 apache configuration files under /etc/apache2/sites-enabled folder.
$ cat /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
DocumentRoot /var/www/html
ErrorLog /var/www/html/log/http.error
RewriteEngine on
RewriteCond %{SERVER_NAME} =christineonline.tk
$ cat /etc/apache2/sites-enabled/000-default-le-ssl.conf
<VirtualHost *:443>
ServerName christineonline.tk
SSLCertificateFile /etc/letsencrypt/live/christineonline.tk/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/christineonline.tk/privkey.pem
I don’t have too much knownledge with Apache server but it sounds an issue with my Apache domain configuration or maybe I’m wrong.
Can you please support me to troubleshoot my issue to get new domain certificate ?
Many thanks for your support,
Best Regards
Cyril
I don’t understand why you thought you had to revoke a certificate you don’t need anymore.
Deletion is more than enough for that.
Your port 80 vhost config has no servername and the rewrite to HTTPS will no longer work as it only compares to the old .tk name.
Your port 443 vhost config has a servername for the old .tk domain only.
There is no config to service the new .ml name.
You need to read up on how to configure your web server.
Hi rg305 and entire community,
Finally, I managed this morning to solve my Apache2 issue. And sorry to disturb here.
Here is how I solved it.
First I have updated my hosts file to include new ServerName.
Then, I rewrite completely my .conf file as following
$ cat /etc/apache2/sites-available/000-default.conf
<VirtualHost *:80>
ServerName christineonline.ml
RewriteEngine on
RewriteCond %{SERVER_NAME} =christineonline.ml
$ cat /etc/apache2/sites-available/000-default-le-ssl.conf
<VirtualHost *:443>
SSLEngine on
SSLProtocol all -SSLv2 -SSLv3
SSLCertificateFile /etc/letsencrypt/live/christineonline.ml/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/christineonline.ml/privkey.pem
<VirtualHost *:80>
RewriteEngine on
Some rewrite rules in this file were disabled on your HTTPS site,
because they have the potential to create redirection loops.
And activate the new virtual host
sudo a2ensite 000-default.conf
And get successfully my new domain with revised virtual host as certified !
Sorry for disturbing and thanks for your consideration,
Best Regards
Cyril
I’m glad my post helped you get a cert, but it still looks like you may have a server name in two places doing the same thing.
Please show output of:
apachectl -S
Hi rg305,
Thanks for supporting my issue !
Here below is the commande output :
$ sudo apachectl -S
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/apache2.conf:235
VirtualHost configuration:
*:443 christineonline.ml (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 is a NameVirtualHost
default server christineonline.ml (/etc/apache2/sites-enabled/000-default-le-ssl.conf:16)
port 80 namevhost christineonline.ml (/etc/apache2/sites-enabled/000-default-le-ssl.conf:16)
port 80 namevhost christineonline.ml (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: ā€œ/etc/apache2ā€
Main DocumentRoot: ā€œ/var/www/htmlā€
Main ErrorLog: ā€œ/var/www/html/log/http.errorā€
PidFile: ā€œ/var/run/apache2/apache2.pidā€
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=ā€œwww-dataā€ id=33
Group: name=ā€œwww-dataā€ id=33
Thanks again for your help
Best Regards
Cyril
This is an overlap/name conflict. Each name should only appear in one vhost config per service.
[once for HTTP and once for HTTPS]
Here we see that port 80 (HTTP) has the same name in two vhost configs.
Hi rg305,
Ok so this is what I did to have a clean vhost configuration:
a2dissite 000-default-le-ssl.conf service apache2 restart
Then I have remove all redirect settings from 000-default.conf.
And have deleted the 000-default-le-ssl.conf
Then I have run again for cert-bot
OUTPUT :
./certbot-auto --apache --domain christineonline.ml --email cyrillouiphone@gmail.com
Created an SSL vhost at /etc/apache2/sites-available/000-default-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/000-default-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/000-default-le-ssl.conf
Redirecting vhost in /etc/apache2/sites-enabled/000-default.conf to ssl vhost in /etc/apache2/sites-available/000-default-le-ssl.conf
Congratulations! You have successfully enabled https://christineonline.ml
https://www.ssllabs.com/ssltest/analyze.html?d=christineonline.ml
    /etc/letsencrypt/live/christineonline.ml-0001/fullchain.pem
    /etc/letsencrypt/live/christineonline.ml-0001/privkey.pem
    Your cert will expire on 2020-08-11. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again with the ā€œcertonlyā€ option. To non-interactively renew all
    of your certificates, run ā€œcertbot-auto renewā€
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
This have created a new folder for certificate into /etc/letsencrypt/live/christineonline.ml-0001/
And also have created a new SSL conf file 000-default-le-ssl.conf :
<VirtualHost *:443>
SSLCertificateFile /etc/letsencrypt/live/christineonline.ml-0001/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/christineonline.ml-0001/privkey.pem
Website is active on HTTPS 443 and certificate also active.
However, when I run for
$apachectl -S
OUTPUT
AH00526: Syntax error on line 8 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file ā€˜/etc/letsencrypt/live/christineonline.ml-0001/fullchain.pem’ does not exist or is empty
Action ā€˜configtest’ failed.
Really strange because .pem files are in the live folder /christineonline.ml-001/
Sounds like Apache couldn’t read inside .
Is it a R/W file issue ?
Many thanks again
Best Regards
certbot certificates
[there we will see what file names should be used]
And also, just for sanity check:
ls -l /etc/letsencrypt/live/christineonline.ml-0001/
Hi again and thanks for your quick answer.
Here is the output of $ certbot certificates
OUTPUT
Renewal configuration file /etc/letsencrypt/renewal/christineonline.ml.conf produced an unexpected error: expected /etc/letsencrypt/live/christineonline.ml/cert.pem to be a symlink. Skipping.
Found the following certs:
Certificate Name: christineonline.ml-0001
Serial Number: 304e6b719ba6e891da582aace336f309c41
Domains: christineonline.ml
Expiry Date: 2020-08-11 13:41:32+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/christineonline.ml-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/christineonline.ml-0001/privkey.pem
The following renewal configurations were invalid:
And here list of files of the folder :
total 4
lrwxrwxrwx 1 root root 47 May 13 16:41 cert.pem -> …/…/archive/christineonline.ml-0001/cert1.pem
lrwxrwxrwx 1 root root 48 May 13 16:41 chain.pem -> …/…/archive/christineonline.ml-0001/chain1.pem
lrwxrwxrwx 1 root root 52 May 13 16:41 fullchain.pem -> …/…/archive/christineonline.ml-0001/fullchain1.pem
lrwxrwxrwx 1 root root 50 May 13 16:41 privkey.pem -> …/…/archive/christineonline.ml-0001/privkey1.pem
-rw-r–r-- 1 root root 692 May 13 16:41 README
Many thanks again !
Please show:
ls -l /etc/letsencrypt/live/christineonline.ml/
ls -l /etc/letsencrypt/renewal/
That may need to be removed.
Please also show:
ls -l /etc/letsencrypt/archive/christineonline.ml-0001/
Ok so I will now share output without deleting old renewal .conf.
total 12
drwxr-xr-x 2 root root 4096 May 13 16:34 christineonline.ml
drwxr-xr-x 2 root root 4096 May 13 16:41 christineonline.ml-0001
-rw-r–r-- 1 root root 740 May 13 09:52 README
total 4
-rw-r–r-- 1 root root 692 May 13 09:52 README
total 8
-rw-r–r-- 1 root root 573 May 13 16:41 christineonline.ml-0001.conf
-rw-r–r-- 1 root root 611 May 13 09:52 christineonline.ml.conf
total 16
-rw-r–r-- 1 root root 1919 May 13 16:41 cert1.pem
-rw-r–r-- 1 root root 1647 May 13 16:41 chain1.pem
-rw-r–r-- 1 root root 3566 May 13 16:41 fullchain1.pem
-rw------- 1 root root 1704 May 13 16:41 privkey1.pem
Thanks again for your help !
Two renewal files but only one is valid:
Two live folders, but only one have files in it:
[EMPTY]
At some point, you probably tried deleting things manually…
That is not a good idea.
[There are too many moving parts to deal with ā€œmanuallyā€]
I suggest you try to using cerbot to delete the bad cert stuff.
certbot delete --cert-name christineonline.ml
Then recheck the renewals.
If it works, stop here and jump for joy - LOL
If that still ā€œfailsā€, try to ā€œcleanupā€ the remnants of the initial unused cert manually.
rm -R /etc/letsencrypt/live/christineonline.ml/
rm /etc/letsencrypt/renewal/christineonline.ml.conf/
Then re-recheck the renewals.
That better work!
Guess what ? certbot delete did the thing !
No more christineonline.ml in renewal or somewhere else.
I did some other checks and problem is 100% solved !
Thanks a lot for your great support :+1: :partying_face:
Have a nice evening
Best Regards
