The operating system my web server runs on is (include version): ESP8266
Hi there,
I have a question about how LetsEncypt handles an authenticator validation and then how the resultant certs can be subsequently used. I am trying to setup an SSL web server on an ESP8266 Arduino variant board. I can get this working using a self-signed cert but this is no good to me because all browsers nowadays by default block access to web servers delivered via self-signed SSL links.
My question is, is it possible to create a LetsEncrypt cert using certbot and associate it with a Domain A that I own - I can run the certbot command on a machine that is pointed to by Domain A - and then take this cert and use it as the cert for the Arduino web server? I have a DNS server running on the Arduino that can be set up to point Domain A to the address of the Arduino.
Does that make sense? Any help would be greatly appreciated.
Thanks Steven. So, is this the way SSL Trust works for a browser?
-Browser 1 requests a page from example.com on port 443.
-The DNS server points example.com to 192.168.0.1.
-Browser 1 gets the SSL cert from the web server at 192.168.0.1. It checks that the cert is registered to example.com and that its parent CA is trusted.
-If Browser 1 is satisfied, it downloads and displays the site without warnings.
The cert is not tied to any IP address at all. It can be used on any IP address and can be used on more than one server at once if necessary. Indeed, the browser just checks whether the name on the certificate matches the name of the service that the browser is trying to access, without regard to what IP address was used to reach that service (or even whether it was reached via an IP address at all—for example, with a SOCKS proxy there is no remote IP address visible to the browser).
One thing to consider when using the certificate on your Arduino is that Let’s Encrypt certificates are only valid for 90 days (possibly shorter times at some point in the future), so you’ll also need a plan for getting new certificates onto the device before the old ones expire.
Thanks Schoen. That’s very clear. And yes, your point about the 90 days expiration is well made. I wonder how much work would be involved in writing a cert renew function for the ESP8266. Would you know of a good resource that explains the cert renew process?
The cert renewal process basically just involves requesting a new certificate. Most existing clients support it; the more complicated part is typically remembering the settings that need to be used to obtain the certificate and also deciding when to request the new certificate and where to save it.
Assuming you’re obtaining the certificate using a device other than the Arduino, could you use that device for renewals as well? It seems like running a full client on an Arduino might be a lot of effort.
