Pre-hook script not found in PATH
Hello,
I’m using Certbot with Docker and have some problems with pre and post hooks. For example I want restart nginx container.
I’m using command below:
sudo docker run -it --rm --name certbot \
-v "/etc/letsencrypt:/etc/letsencrypt" \
-v "/var/lib/letsencrypt:/var/lib/letsencrypt" \
-v "/var/log/letsencrypt:/var/log/letsencrypt" \
-v "/var/run/docker.sock:/var/run/docker.sock" \
-v $(which docker):/usr/bin/docker \
-e AWS_ACCESS_KEY_ID="****" \
-e AWS_SECRET_ACCESS_KEY="****" \
certbot/dns-route53 certonly --dns-route53 --dry-run -d example.net -d www.example.net --pre-hook "/usr/bin/docker restart nginx"
Found credentials in environment variables.
Plugins selected: Authenticator dns-route53, Installer None
Running pre-hook command: /usr/bin/docker restart nginx
pre-hook command "/usr/bin/docker restart nginx" returned error code 127
Error output from pre-hook command docker:
/bin/sh: /usr/bin/docker: not found
dns-01 challenge for example.net
dns-01 challenge for www.example.net
 - The dry run was successful.
ubuntu@ip-172-31-34-210:~$
Does anybody know if this achivable at all? I mean using hooks if you use Certbot with Docker.
The issue is that the docker binary from your host system is not compatible with the libc/loader inside the Certbot container, which is based on Alpine/musl.
My suggestion would be to figure out some way to run apk add docker inside the container first (perhaps using --entrypoint or by creating your own Docker image based on the Certbot image).
As long as you continue to mount the socket from the host system, everything should still work.
Cool. Many thanks for explanation!
