Post-installation redirect question
I just ran certbot on a linux nginx server. the installation was just beautifully simple. I played around with it a year or two ago, and it was not bad. but now it was just perfect. thank you, letsencrypt team
I have one question only. my site is working so well that I would like to change my answer from 1 to 2 in
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
it would be ideal if certbot could recommend at this prompt exactly how to rerun this.
  • is the recommended way to uninstall certbot and do it again?
  • to run certbot --nginx again?
  • to do something else?
ideally, there could even be a command line script that can do and undo this.
Hi @iaw4
check the documentation:
https://certbot.eff.org/docs/using.html#certbot-command-line-options
--redirect and --no-redirect - then the redirect is created.
