Possible to get SSL for webservers public ip?
Hello, im currently learning web development and im not quiet sure i grasp how the concept of SSL works.
Im currently working on a testserver, its a Nextcloud instance running on an Ubuntu machine that i have made public trough port forwarding. I access it trough my public IP. But i really dont like opening a none-encrypted server to the internet.
Is it possible for me to add SSL to this since its connected trough IP and not a domain?
I tried using the CertBot-auto but couldnt get it to work(im new with this so could be i did something wrong).
In case i do need a domain, i actually own www.iamkaspernielsen.com
would it be possible for me to get a SSL cert for that and use it on my Nextcloud server somehow?
Any tips or feedback will be greatly appreciated!
Kind regards
Kasper
Hi @KalleDania
no, that's not possible, you need a public visible and unique domain name.
Start with the basics:
Then share your results:
Sure, if you aren't using it for anything else and it points to your Nextcloud installation. If it doesn't, perhaps you could use a different subdomain like cloud.iamkaspernielsen.com.
