Sure, here's the result
> ping -c 10 acme-v02.api.letsencrypt.org
PING ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com (172.65.32.248) 56(84) bytes of data.
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=1 ttl=49 time=149 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=2 ttl=49 time=130 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=3 ttl=49 time=130 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=4 ttl=49 time=130 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=5 ttl=49 time=130 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=6 ttl=49 time=130 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=7 ttl=49 time=130 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=8 ttl=49 time=130 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=9 ttl=49 time=130 ms
64 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=10 ttl=49 time=130 ms
--- ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9322ms
rtt min/avg/max/mdev = 129.770/131.746/148.683/5.645 ms
rg305
August 3, 2022, 3:09am
22
So... either:
hmm...
Sounds like possible routing or congestion issues.
15 hops is a lot on the Internet.
rg305
August 3, 2022, 3:10am
23
[I'm surprised it didn't choose an IPv6 address]
rg305
August 3, 2022, 3:11am
24
What shows?:
ping -c 2 -s 1492 acme-v02.api.letsencrypt.org
ping -c 2 -s 1400 acme-v02.api.letsencrypt.org
rg305:
$ nslookup acme-v02.api.letsencrypt.org
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
acme-v02.api.letsencrypt.org canonical name = prod.api.letsencrypt.org.
prod.api.letsencrypt.org canonical name = ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com.
Address: 172.65.32.248
Address: 2606:4700:60:0:f53d:5624:85c7:3a2c
$ ping -c 2 -s 1492 acme-v02.api.letsencrypt.org
PING ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com (172.65.32.248) 1492(1520) bytes of data.
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=1 ttl=49 time=244 ms
2 packets transmitted, 1 received, 50% packet loss, time 1001ms
rtt min/avg/max/mdev = 244.394/244.394/244.394/0.000 ms
$ ping -c 2 -s 1400 acme-v02.api.letsencrypt.org
PING ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com (172.65.32.248) 1400(1428) bytes of data.
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=1 ttl=49 time=245 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=2 ttl=49 time=245 ms
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 244.581/244.625/244.669/0.044 ms
rg305
August 3, 2022, 3:23am
26
Let's increase these numbers:
Also, it's strange that is doesn't prefer the IPv6 number:
rg305
August 3, 2022, 3:25am
27
I get:
ping -c 10 -s 1492 acme-v02.api.letsencrypt.org
PING acme-v02.api.letsencrypt.org(2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c)) 1492 data bytes
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=1 ttl=57 time=9.68 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=2 ttl=57 time=8.66 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=3 ttl=57 time=8.29 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=4 ttl=57 time=8.96 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=5 ttl=57 time=10.2 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=6 ttl=57 time=8.24 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=7 ttl=57 time=9.07 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=8 ttl=57 time=8.21 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=9 ttl=57 time=10.9 ms
1500 bytes from 2606:4700:60:0:f53d:5624:85c7:3a2c (2606:4700:60:0:f53d:5624:85c7:3a2c): icmp_seq=10 ttl=57 time=7.77 ms
--- acme-v02.api.letsencrypt.org ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9012ms
rtt min/avg/max/mdev = 7.778/9.009/10.927/0.955 ms
$ ping -c 10 -s 1492 acme-v02.api.letsencrypt.org
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=1 ttl=49 time=154 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=2 ttl=49 time=154 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=3 ttl=49 time=152 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=4 ttl=49 time=148 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=5 ttl=49 time=161 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=6 ttl=49 time=150 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=7 ttl=49 time=148 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=8 ttl=49 time=154 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=9 ttl=49 time=156 ms
1500 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=10 ttl=49 time=152 ms
rtt min/avg/max/mdev = 147.633/152.760/160.840/3.750 ms
$ ping -c 10 -s 1400 acme-v02.api.letsencrypt.org
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=1 ttl=49 time=148 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=2 ttl=49 time=148 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=3 ttl=49 time=148 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=4 ttl=49 time=149 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=5 ttl=49 time=148 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=6 ttl=49 time=148 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=7 ttl=49 time=151 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=8 ttl=49 time=148 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=9 ttl=49 time=148 ms
1408 bytes from 172.65.32.248 (172.65.32.248): icmp_seq=10 ttl=49 time=148 ms
10 packets transmitted, 10 received, 0% packet loss, time 9013ms
rtt min/avg/max/mdev = 147.605/148.118/150.620/0.967 ms
rg305
August 3, 2022, 3:43am
29
hmm...
Then the problem seems to be transient/temporary.
Try again:
certbot --apache
rg305
August 3, 2022, 3:47am
30
That is still troubling me ...
Show:
curl -6 https://acme-v02.api.letsencrypt.org/
curl -6 https://ipv6.org/
My ping needs ping -6
to use IPv6. Maybe version or distro difference?
That seems to be an issue. Both respond with an issue
$ curl -6 https://acme-v02.api.letsencrypt.org/
curl: (7) Couldn't connect to server
$ curl -6 https://ipv6.org/
I also tried to do these 2 requests on another of our working server (101.132.227.218). It also have the same errors but can still do certbot --apache
without any problems.
rg305
August 3, 2022, 3:53am
33
IPv6 seems to be broken :
Please show:
ifconfig | grep -Ei 'add|inet'
$ ifconfig | grep -Ei 'add|inet'
br-aadddda641e6: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.18.0.1 netmask 255.255.0.0 broadcast 172.18.255.255
inet6 fe80::42:59ff:fefd:3fa7 prefixlen 64 scopeid 0x20<link>
inet 172.19.0.1 netmask 255.255.0.0 broadcast 172.19.255.255
inet6 fe80::42:f6ff:fef5:5568 prefixlen 64 scopeid 0x20<link>
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
inet6 fe80::42:9dff:fecd:c004 prefixlen 64 scopeid 0x20<link>
inet 172.16.62.211 netmask 255.255.240.0 broadcast 172.16.63.255
inet6 fe80::216:3eff:fe10:3c89 prefixlen 64 scopeid 0x20<link>
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
inet6 fe80::646f:bff:fe87:22e3 prefixlen 64 scopeid 0x20<link>
inet6 fe80::11:7ff:feaf:b4a9 prefixlen 64 scopeid 0x20<link>
inet6 fe80::18aa:8dff:fe2f:e2c0 prefixlen 64 scopeid 0x20<link>
rg305
August 3, 2022, 3:57am
36
All those IPv6 addresses are private local ("fe80::
Please show:
curl -k https://172.65.32.248/
rg305
August 3, 2022, 3:59am
37
And let's have a look at the LE log file, after:
certbot --apache -vv
On that one I finally have a difference between our working server and the one with an issue. The working server is returning the html content of the page. whereas or problem server returns a timeout:
$ curl -k https://172.65.32.248/
curl: (35) OpenSSL SSL_connect: Connection reset by peer in connection to 172.65.32.248:443
rg305
August 3, 2022, 4:04am
39
OK,. we have a constantly failing test!
Now to find the why and the where ...
Is there a firewall?
rg305
August 3, 2022, 4:06am
40
Also, try:
curl -k https://8.8.8.8/
We're using ufw on the server side but there might some additional settings from the provider (Aliyun)
Here's the status of ufw:
$ ufw status
Status: active
To Action From
22/tcp ALLOW Anywhere
22 ALLOW Anywhere
80/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
10000/tcp ALLOW Anywhere
10000 ALLOW Anywhere
1000/tcp ALLOW Anywhere
465 ALLOW Anywhere
8989 ALLOW Anywhere
9200 ALLOW Anywhere
22/tcp (v6) ALLOW Anywhere (v6)
22 (v6) ALLOW Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
10000/tcp (v6) ALLOW Anywhere (v6)
10000 (v6) ALLOW Anywhere (v6)
1000/tcp (v6) ALLOW Anywhere (v6)
465 (v6) ALLOW Anywhere (v6)
8989 (v6) ALLOW Anywhere (v6)
9200 (v6) ALLOW Anywhere (v6)
