Hi guys ,
I have a problem when iam trying to install lets’sencrypt on centos OS
i got the following error  "Port 443 is already in use by another process "
please find the screenshot blow
Hi guys ,
Don’t use standalone, you’ve probably got a webserver running…
Thank you but it doesn’t works with Hostgator
Well, you didn’t tell about Hostgator, now did you
You can’t expect us to have crystal balls
As @Osiris says, without all the information it’s a bit tricky to provide an answer. Can you provide a bit more info; the default template is …
Lol  you’re right !
i mean its works on my own server but hostgator server it’s not
Hostgator offers many different services… Do you have simple hosting only? I.e., shared hosting. Or a VPS? You’re still not giving much to help you… Please fill in the template @serverco mentioned, it’s there for a good reason… (Why did you delete it anyway?)
My domain is: lifeofsite.com
I ran this command: ./letsencrypt-auto certonly
It produced this output: Failed authorization procedure. lifeofsite.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://lifeofsite.com/.well-known/acme-challenge/74NAW-IIhNt0abN-meh0AdgjxzcLsaPVMUqjuhVr8go: "
404 Not FoundIMPORTANT NOTES:
Domain: lifeofsite.com
Type:   unauthorized
Detail: Invalid response from
Domain: www.lifeofsite.com
Type:   unauthorized
http://www.lifeofsite.com/.well-known/acme-challenge/HDLXK6LPKBVbKaX7sCTxhZsRi3dEDHmIEEsVFJIkckQ:
My operating system is (include version): CentOS 6.8
My web server is (include version): Apache/2.2.31
My hosting provider, if applicable, is: hostgator
