We issued a cert for our server with no problem, but when we renewed it, the browsers stop recognizing the certificate and the connection times out.
How do we resolve this problem?
Hi @lightfoot,
You would receive more help if you provide your real domain name, the command/tool used to issue your cert, the command used to renewe it, your web server, if it is a shared hosting or not, if it is Windows, Linux, MacOS, the error message, etc.
Please, fill these questions:
Cheers,
sahsanu
Hello sahsanu:
Thank you for the quick response:
The domain: https://tasktaxi.com:8443/login_up.php3
This is the login page for my server - the cert works fine on https://tasktaxi.com
I am using the Plesk Onyx (17) admin panel with Centos 6.7
I installed the cert via the panel
Yes I have root access.
Web server is Nginx.
Let me know if you need more information.
Thank you for your time,
Lightfoot
you are not using the same certificate
your 8443 binding
your port 443 biding
i can confirm you have multiple certificates issued as well
https://crt.sh/?q=tasktaxi.com
how and why this is happening and how to fix it is more a question for Plesk support/forums
Andrei
i have also updated your title so others who may be experienced with plesk or seen a similar problem can help
Hi @lightfoot,
As @ahaw021 comments, you are serving 2 different certificates, the right one on nginx port 443 and the expired one in a service named sw-cp-server on port 8443.
I don’t know what sw-cp-server service does but or you need to restart it or you need to configure it properly to serve your current certificate.
Sorry but I don’t use Plesk so no idea how it works.
Cheers,
sahsanu
Hello Andrei:
Thank you very much for this information-I will contact Plesk support to resolve the problem.
Thank you Sahsanu - I appreciate your help with this problem.
