Please help on ACME Challenge on site http://yw.duopu.cn/
I’m getting trouble to complete ACME challenge even the http response is exactly same as required, please help to check it.
When I check the challenge status on this url:
https://acme-v01.api.letsencrypt.org/acme/challenge/mfWG-XkaoX-y-6pOor1nKYI55QIcpTcHMIYtHfPG_zY/2768023139
I got this response:
“type”: “http-01”,
“status”: “invalid”,
“error”: {
“type”: “urn:acme:error:unauthorized”,
“detail”: “The key authorization file from the server did not match this challenge [ODdWrr0UJW3HdyGWNcUA5S3BpZvsE3lXEyLfxsN23-A.PmxcITz36tYkGadb_Ti8ApByYtI0VhTKs_jHPnQvFro] != [ODdWrr0UJW3HdyGWNcUA5S3BpZvsE3lXEyLfxsN23-A.PmxcITz36tYkGadb_Ti8ApByYtI0VhTKs_jHPnQvFro]”,
“status”: 403
“uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/mfWG-XkaoX-y-6pOor1nKYI55QIcpTcHMIYtHfPG_zY/2768023139”,
“token”: “ODdWrr0UJW3HdyGWNcUA5S3BpZvsE3lXEyLfxsN23-A”,
“keyAuthorization”: “ODdWrr0UJW3HdyGWNcUA5S3BpZvsE3lXEyLfxsN23-A.PmxcITz36tYkGadb_Ti8ApByYtI0VhTKs_jHPnQvFro”,
“validationRecord”: [
“url”: “http://yw.duopu.cn/.well-known/acme-challenge/ODdWrr0UJW3HdyGWNcUA5S3BpZvsE3lXEyLfxsN23-A”,
“hostname”: “yw.duopu.cn”,
“port”: “80”,
“addressesResolved”: [
“114.55.59.234”
“addressUsed”: “114.55.59.234”,
“addressesTried”: []
http://yw.duopu.cn/
I ran this command on PowerShell:
Submit-ACMEChallenge dns3 -ChallengeType http-01
IdentifierPart : ACMESharp.Messages.IdentifierPart
IdentifierType : dns
Identifier : yw.duopu.cn
Uri : https://acme-v01.api.letsencrypt.org/acme/authz/mfWG-XkaoX-y-6pOor1nKYI55QIcpTcHMIYtHfPG_zY
Status : pending
Expires : 2017/12/24 4:50:09
Challenges : {, manual, }
Combinations : {1, 0, 2}
Apache/2.2.22 (Win32)
Windows Server 2012
Alicloud
Yes, I login via Microsoft Remote Desktop
It’s not actually exactly the same. It’s not visible in the error message – or your browser, or most text editors – but the file on the server starts with a UTF-8 byte order mark.
00000000  ef bb bf 4f 44 64 57 72  72 30 55 4a 57 33 48 64  |...ODdWrr0UJW3Hd|
00000010  79 47 57 4e 63 55 41 35  53 33 42 70 5a 76 73 45  |yGWNcUA5S3BpZvsE|
00000020  33 6c 58 45 79 4c 66 78  73 4e 32 33 2d 41 2e 50  |3lXEyLfxsN23-A.P|
00000030  6d 78 63 49 54 7a 33 36  74 59 6b 47 61 64 62 5f  |mxcITz36tYkGadb_|
00000040  54 69 38 41 70 42 79 59  74 49 30 56 68 54 4b 73  |Ti8ApByYtI0VhTKs|
00000050  5f 6a 48 50 6e 51 76 46  72 6f                    |_jHPnQvFro|
0000005a
I think you need to make sure it doesn’t. :sweat:
Thank you so much!
I saved the file as UTF-8 format, after I try again with ANSI encode, it works well now.
Really appreciate!
