Please help me with updating the certificate, what am I doing wrong?
Hello, tell me why I can't update the certificate? Port 80 and 443 are open. But certbot stubbornly refuses to update the certificate.
nmap -Pn -p 80,443 lkmpikt.org
Starting Nmap 7.80 ( https://nmap.org ) at 2025-01-24 15:12 MSK
Nmap scan report for lkmpikt.org (194.31.153.37)
Host is up (0.00076s latency).
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 0.05 seconds
sudo certbot --expand -d lkmpikt.org -d md.lkmpikt.org
Attempting to parse the version 2.11.0 renewal configuration file found at /etc/letsencrypt/renewal/lkmpikt.org.conf with version 0.40.0 of Certbot. This might not work.
http-01 challenge for lkmpikt.org
http-01 challenge for md.lkmpikt.org
Challenge failed for domain lkmpikt.org
Challenge failed for domain md.lkmpikt.org
   Domain: lkmpikt.org
   Type:   connection
   Detail: 194.31.153.37: Fetching
   http://lkmpikt.org/.well-known/acme-challenge/E6_BPv0PJbLj_PkrC617f7svh7nl9ezsEYr1a8oJszM:
   Domain: md.lkmpikt.org
   Type:   connection
   http://md.lkmpikt.org/.well-known/acme-challenge/Y0o_M3zXFhiDasP-pI67lo_tsNbR5oSUIn3-yh_N0oI:
sudo certbot --version
certbot 0.40.0
Hello,
The port being open means that there is no TCP reset or ICMP unreachable packet received. You still need a service (in that case web server) to listen on the port.
tumbleweed:~ # curl -s -v lkmpikt.org
* Host lkmpikt.org:80 was resolved.
* IPv6: (none)
* IPv4: 194.31.153.37
*   Trying 194.31.153.37:80...
* connect to 194.31.153.37 port 80 from 192.168.1.2 port 35034 failed: Connection timed out
* Failed to connect to lkmpikt.org port 80 after 134483 ms: Could not connect to server
* closing connection #0
tumbleweed:~ #
sudo curl -s -v lkmpikt.org
* TCP_NODELAY set
* Connected to lkmpikt.org (194.31.153.37) port 80 (#0)
> GET / HTTP/1.1
> Host: lkmpikt.org
> User-Agent: curl/7.68.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 302 Moved Temporarily
< Server: nginx/1.18.0 (Ubuntu)
< Date: Fri, 24 Jan 2025 12:32:12 GMT
< Content-Type: text/html
< Content-Length: 154
< Connection: keep-alive
< Location: https://lkmpikt.org/
<html>
<head><title>302 Found</title></head>
<body>
<center><h1>302 Found</h1></center>
<hr><center>nginx/1.18.0 (Ubuntu)</center>
</body>
</html>
* Connection #0 to host lkmpikt.org left intact
Are you using some geoIP blocking service?
Was that from your local network? Because from the public internet requests are failing
No, I do not use a geoIP blocking service.
No internet I use this command via the internet. Not locally
Perhaps, if there is a blocking, then most likely it is from the providers
Yes, you may want to check this with your provider (luganet?).
tumbleweed:~ # mtr -r -b -w lkmpikt.org
Start: 2025-01-24T12:48:01+0000
HOST: tumbleweed.home                                  Loss%   Snt   Last   Avg  Best  Wrst StDev
  1.|-- livebox.home (192.168.1.1)                        0.0%    10    0.5   0.7   0.5   2.3   0.6
  2.|-- 80.10.5.237                                       0.0%    10    1.7   2.0   1.7   2.3   0.2
  3.|-- 92.184.150.74                                     0.0%    10    2.9   2.8   2.5   3.0   0.2
  4.|-- ae42-0.nilyo101.rbci.orange.net (193.252.101.89)  0.0%    10    6.0   6.3   5.7  10.1   1.3
  5.|-- ???                                              100.0    10    0.0   0.0   0.0   0.0   0.0
  6.|-- 193.251.250.190                                   0.0%    10   13.5  10.8   9.3  14.9   2.0
  7.|-- 87-245-232-54.retn.net (87.245.232.54)            0.0%    10   61.3  61.1  58.1  70.4   4.0
  8.|-- 139.45.229.193                                    0.0%    10   58.4  58.3  58.1  58.5   0.1
  9.|-- pool.luganet.ru (194.31.155.241)                  0.0%    10   74.8  73.4  72.2  76.6   1.5
        pool.luganet.ru (194.31.155.239)
 10.|-- ???                                              100.0    10    0.0   0.0   0.0   0.0   0.0
tumbleweed:~ #
The amazing is nearby.... The certificate was issued after the weekend. And everything worked. I still didn't understand what it was. After all, on Friday, certbot did not want to issue a certificate. But, I came to work today, the site is now working correctly.
