Please help a website
#1
Please help a website link that appears to be unsafe. What is the reason? Please find it as soon as possible in the best possible way
https://hotline-transport.com/
#2
The certificate installed on the web server, does not contain the hotline-transport.com domain. When you request a certificate, you can request multiple domains and then install that certificate to serve valid https certification to multiple sites in a single server.
Check out this thread: (more than one domain, one certificate and one server):
#3
Hi @namecheap
it’s not enough to activate only https / Port 443. You have to create a certificate and install ist.
#4
