My domain is: *.xolm-ph.com
My web server is (include version): NGINX
The operating system my web server runs on is (include version): Debian GNU/Linux 11 (bullseye)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Portainer
Hi, I'm running an Nginx Reverse Proxy in a Docker.
Trying to add a Let's Encrypt SSL and I'm getting this error:
Error: Command failed: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-14" --agree-tos --email "xxx@gmail.com" --domains "*.xxxx-yy.com,homelab.xxxx-yy.com" --authenticator dns-google-domains --dns-google-domains-credentials "/etc/letsencrypt/credentials/credentials-14"
An unexpected error occurred:
pkg_resources.VersionConflict: (zope.interface 5.4.0 (/tmp/npmuserhome/.local/lib/python3.7/site-packages), Requirement.parse('zope.interface>=5.5.0'))
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/certbot-log-63q1__vq/log or re-run Certbot with -v for more details.
at ChildProcess.exithandler (node:child_process:402:12)
at ChildProcess.emit (node:events:513:28)
at maybeClose (node:internal/child_process:1100:16)
at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
Hi @xomanuel, and welcome to the LE community forum
Please take the time to answer the questions below - which you should have been presented with when choosing the "Help" category:
Let me first state that I personally have the opinion NPM is a terrible piece of software, as it usually makes debugging Certbot/certificate issues really difficult. I would never advice anyone to use it.
That said, can you please provide your Docker settings? I.e., Dockerfile et cetera. Be aware it might be something we can't help fixing. It looks like an incompatibility between installed Python packages and this might be something only NPM can fix. But we'd need to have more information.
I would never recommend that: looks like with that command you'd install stuff on your base system with pip globally: so neither within the NPM container nor within a virtual environment!
