The operating system my web server runs on is (include version): ubuntu 20.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.24.0
I setup nginx with letsencrypt and all went well.
I then installed phpmyadmin and while I can login and see standard phpmyadmin menu items, the list of databases on the left briefly shows and then disappears. Also the central frame where you usually see database details is empty.
When I look at the page source code both frames appear empty.
The nginx error log does not offer any hints. Searching online has not been fruitful either. Please help!
Does phpmyadmin know it's supposed to load over https or do its settings still include an http address? Open your browser console and check if there are errors there.
(If that's the issue, this is a bug in phpmyadmin: you can just use href="//phpmyadmin.example.com/index.php" without actually specifying the scheme, and it will work)
The html is just blank where there should be content and I can see ""
Digging into the nginx logs, I just found SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: x.x.x.x , server: 0.0.0.0:443 so will do some googling
Those frames are loaded from the same domain/subdomain phpmyadmin is installed on, right? I don't know why you only get this error on some requests and not others.
