My domain is: sensi.com.au
Starting NGINX service or using test:
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu 22.04LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
The actual certificate file is in /etc/letsencrypt/archive and the permissions are fine. The symlink to the actual fullchain.pem is also fine and I can read the file without problems and there are no obvious issues.
This system has been working for some time, it stopped when adding some additional sites to NGINX config.
The other sites which also use Letsencrypt certificates are working. It's only this one (which is a wildcard certificate, BTW, in case this matters) that is not able to be loaded by NGINX.
I have gone through everything. Does anyone know how to get more detailed debug info from NGINX or some OpenSSL command that would help get to the bottom of the issue?
If that's ok then the most likely thing is the nginx configuration file is literally pointing to fullchain.pem for the actual private key instead of privkey.pem
