vidaporluna.com.br
Nginx reverse proxy -> wordpresss Docker container
CWP pro (centos web Panel)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.20.0
The CWP generated several certificates, now I'm trying to create a certificate and it says it exceeded the limit.
I really need your help to release only 1 certificate. is very urgent. I was going to launch the site today.
I'm stuck without getting it, because I don't have the old panel to get the private key to revoke.
I can't revoke or create.
Please ask for a help.
If you have to pay any release fees, please advise
here message
Errors occurred on installation process.
- vidaporluna.com.br
Error Message: [Mon Dec 6 07:40:20 -03 2021] Using CA: https://acme-v02.api.letsencrypt.org/directory [Mon Dec 6 07:40:20 -03 2021] Single domain='vidaporluna.com.br' [Mon Dec 6 07:40:20 -03 2021] Getting domain auth token for each domain [Mon Dec 6 07:40:21 -03 2021] Create new order error. Le_OrderFinalize not found. { "type": "urn:ietf:params:acme:error:rateLimited", "detail": "Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: vidaporluna.com.br: see Rate Limits - Let's Encrypt", "status": 429 } [Mon Dec 6 07:40:21 -03 2021] Please check log file for more details: /root/.acme.sh/acme.sh.log
att. Arlindo Ferreira
