My domain is: onlinemoneyminer.com
[root@sentora /]# sudo mv certbot-auto /usr/local/bin/certbot-auto
[root@sentora /]# sudo chown root /usr/local/bin/certbot-auto
[root@sentora /]# sudo chmod 0755 /usr/local/bin/certbot-auto
[root@sentora /]# sudo /usr/local/bin/certbot-auto --apache
1: onlinemoneyminer.com
2: mpanel.onlinemoneyminer.com
3: www.onlinemoneyminer.com
blank to select all options shown (Enter ‘c’ to cancel): 1,3
requested (ref: /etc/letsencrypt/renewal/onlinemoneyminer.com-0001.conf)
It contains these names: onlinemoneyminer.com
You requested these names for the new certificate: onlinemoneyminer.com,
www.onlinemoneyminer.com.
certificate?
(E)xpand/©ancel: e
Deploying Certificate to VirtualHost /etc/sentora/configs/apache/httpd-vhosts-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Redirecting vhost in /etc/sentora/configs/apache/httpd-vhosts.conf to ssl vhost in /etc/sentora/configs/apache/httpd-vhost
s-le-ssl.conf
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://onlinemoneyminer.com
and https://www.onlinemoneyminer.com
https://www.ssllabs.com/ssltest/analyze.html?d=onlinemoneyminer.com
https://www.ssllabs.com/ssltest/analyze.html?d=www.onlinemoneyminer.com
/etc/letsencrypt/live/onlinemoneyminer.com-0001/fullchain.pem
/etc/letsencrypt/live/onlinemoneyminer.com-0001/privkey.pem
Your cert will expire on 2020-05-24. To obtain a new or tweaked
version of this certificate in the future, simply run certbot-auto
again with the “certonly” option. To non-interactively renew all
of your certificates, run “certbot-auto renew” - If you like Certbot, please consider supporting our work by:
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My web server is (include version): Apache 2.0
The operating system my web server runs on is (include version): CentOS 7
My hosting provider, if applicable, is: GCP
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Sentora
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): [root@sentora /]# certbot-auto --version
bash: certbot-auto: command not found
Although SSL Certificate installed on my website. The ‘onlinemoneyminer.com’ and ‘www.onlinemoneyminer.com’ and some pages showing “Your connection to this site is not fully secure”
What I am missing?
