Openresty lua fails to renew / re-issue
I’m using openresty with LUA
and since yesterday I’m experiencing troubles getting a certificate
nginx log contains the following lines
2019/10/26 11:25:53 [error] 772#772: *92 [lua] lets_encrypt.lua:41: issue_cert(): auto-ssl: dehydrated failed: env HOOK_SECRET=bf75b46a196d22066bf75b46a196d22066bf75b46a196d22066 HOOK_SERVER_PORT=8999 /usr/local/openresty/luajit/bin/resty-auto-ssl/dehydrated --cron --accept-terms --no-lock --domain freeroll.khelo365.com --challenge http-01 --config /etc/resty-auto-ssl/letsencrypt/config --hook /usr/local/openresty/luajit/bin/resty-auto-ssl/letsencrypt_hooks status: 256 out: # INFO: Using main config file /etc/resty-auto-ssl/letsencrypt/config
# INFO: Using additional config file /etc/resty-auto-ssl/letsencrypt/conf.d/custom.sh
err:
Error retrieving terms of service from certificate authority.
Please set LICENSE in config manually.
, context: ssl_certificate_by_lua*, client: 63.143.42.247, server: 0.0.0.0:443
2019/10/26 11:25:53 [error] 772#772: *92 [lua] ssl_certificate.lua:97: issue_cert(): auto-ssl: issuing new certificate failed: dehydrated failure, context: ssl_certificate_by_lua*, client: 63.143.42.247, server: 0.0.0.0:443
“dehydrated” has not been overriden.
any ideas how to resolve this issue?
Hi @p5ych0
I don't know how that client works. But that looks you should update your client.
Or check
https://acme-v02.api.letsencrypt.org/directory
there is the url of the "termsOfService". Perhaps you can change your config file manual.
my current values are
CA=“https://acme-v01.api.letsencrypt.org/directory”
Path to certificate authority license terms redirect (default: https://acme-v01.api.letsencrypt.org/terms)
CA_TERMS=“https://acme-v01.api.letsencrypt.org/terms”
Path to license agreement (default: )
#LICENSE=""
changing to v01 didn’t help
v1 is deprecated. Read
Support ends 2019-10-31. So you should
  • update your client to use v2 (or, if this isn't possible)
  • switch to another client
PS: That's
wrong. Read the v01 - directory, there is another path and file.
thank you all. updated the client and everything works fine now.
case closed ))
