My domain is: destpark.com
I ran this command: sudo certbot --nginx -d destpark.com -d www.destpark.com
Failed authorization procedure. www.destpark.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.destpark.com/.well-known/acme-challenge/ZH4Qo5UJLHK-uj2cVPhEiqESnXpSFvq-oFoqGdVZDvw: Connection reset by peer, destpark.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.destpark.com/.well-known/acme-challenge/okFZhyakkp3m5xaPa7LTGsUik8vJdqp3rWhxh8KAodY: Connection reset by peer
Domain: www.destpark.com
Type: connection
Detail: Fetching
Connection reset by peerDomain: destpark.com
Type: connection
Detail: Fetching
Connection reset by peerTo fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided. -
Your account credentials have been saved in your Certbot
My web server is (include version): nginx web server
The operating system my web server runs on is (include version): Linux (ubuntu 18.04)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
