NPM : Cant create certificate "Unsafe permission"
Hello everyone,
I pretty new to nginx proxy manager and i want to stop having the certificate alert with my service. I follow a tutorial to do so.
So i install NPM on my server and try to install a certificate for a domain named "intranetcul.duckdns.org" create for my local server. and when i try to create the certificate i got this :
Unsafe permissions on credentials configuration file: /etc/letsencrypt/credentials/credentials-2
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/letsencrypt-log/letsencrypt.log or re-run Certbot with -v for more details.
So i ask you some help to check if you have any idea to resolve that.
Thank for your help.
PS : If you need info i can provide it :wink:
Yeah, we need way more information.. NPM has a habit of omitting essential information. The output you've pasted for example, does not tell us anything useful. Those unsafe permission stuff are probably just warnings. (And to fix those, you should probably refer to an NPM support channel.)
So we really need the actual error message from the ACME server to debug the specific problem.
For example, I have no idea if NPM is actually trying to use the dns-01 challenge using the DuckDNS DNS API, as for your local IP address that's currently configured in your hostname (192.168.1.30), that would be the only viable challenge possible.
Please provide the Certbot log or some way more detailed Certbot output and please also:
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
Please note that most volunteers, me including, are not very inclined to put much effort in debugging NPM, as it's quite a piece of )(#*$() software if you'd ask me. So you might get refered to the NPM support community again for the entirety of your problem in the future.
Yes, im sorry i delete the requirement to open the thread :frowning:
There the info asked (i hope all good)
My domain is: intranetcul.duckdns.org (for local - network)
It produced this output: on the screenshot
My web server is (include version): dont use
The operating system my web server runs on is (include version): Truenas Scale 24.10
My hosting provider, if applicable, is: DuckDNS
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes (i suppose ^^')
The output is inadequate. Even on your screenshot a lot is cut away. (You surely have seen that, right?) But even if you copy/pasted the entire info, it is probably not enough (although that PermissionError is interesting).
Please provide the Certbot log file from, well, somewhere within NPM (I don't have a clue as where to look for that..)
There is what i find for the issue with certbot :
  File "/opt/certbot/bin/certbot", line 8, in <module>
    sys.exit(main())
  File "/opt/certbot/lib/python3.11/site-packages/certbot/main.py", line 19, in main
  File "/opt/certbot/lib/python3.11/site-packages/certbot/_internal/main.py", line 1894, in main
  File "/opt/certbot/lib/python3.11/site-packages/certbot/_internal/main.py", line 1600, in certonly
    lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
  File "/opt/certbot/lib/python3.11/site-packages/certbot/_internal/main.py", line 143, in _get_and_save_cert
  File "/opt/certbot/lib/python3.11/site-packages/certbot/_internal/client.py", line 528, in obtain_and_enroll_certificate
    return storage.RenewableCert.new_lineage(
  File "/opt/certbot/lib/python3.11/site-packages/certbot/_internal/storage.py", line 1126, in new_lineage
    new_config = write_renewal_config(config_filename, config_filename, archive,
  File "/opt/certbot/lib/python3.11/site-packages/certbot/_internal/storage.py", line 171, in write_renewal_config
    filesystem.chmod(n_filename, current_permissions)
  File "/opt/certbot/lib/python3.11/site-packages/certbot/compat/filesystem.py", line 59, in chmod
    os.chmod(file_path, mode)
PermissionError: [Errno 1] Operation not permitted: '/etc/letsencrypt/renewal/npm-4.conf'
2024-12-15 20:05:30,221:ERROR:certbot._internal.log:An unexpected error occurred:
2024-12-15 20:05:30,221:ERROR:certbot._internal.log:PermissionError: [Errno 1] Operation not permitted: '/etc/letsencrypt/renewal/npm-4.conf'
That error should not happen on regular systems. Sounds like some bug in NPM or your specific setup of NPM.
Please refer to the NPM support channels.
