Just got a wildcard cert for domain www works, root domain does not?
This works
https://www.fullymanagedhosting.com/
This does not work
https://fullymanagedhosting.com/
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: fullymanagedhosting.com
My web server is (include version): Apache 2.4.6
The operating system my web server runs on is (include version): CentOS 7.6.18
My hosting provider, if applicable, is: Blue Sky Hosting Ltd
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot-auto 0.34.2
Hi @BlueSky
checking your domain via https://check-your-website.server-daten.de/?q=fullymanagedhosting.com
You have correct DNS entries:
Your www works, your non-www not, you don't have redirects (you should add):
The reason:
CN=*.fullymanagedhosting.com
29.05.2019
27.08.2019
expires in 90 days *.fullymanagedhosting.com - 1 entry
A wildcard domain name doesn't work with the non-www version.
Create one certificate with both domain names:
certbot [yourOtherparameters] -d *.fullymanagedhosting.com -d fullymanagedhosting.com
and use that.
You have only one LE-certificate
CertSpotter-Id
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
937266243
CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US
2019-05-29 09:06:34
2019-08-27 09:06:34
*.fullymanagedhosting.com - 1 entries
duplicate nr. 1
645801994
CN=CloudFlare Inc ECC CA-2, O="CloudFlare, Inc.", L=San Francisco, C=US, ST=CA
2018-11-27 00:00:00
2019-11-27 12:00:00
*.fullymanagedhosting.com, fullymanagedhosting.com , sni.cloudflaressl.com - 3 entries
So there is no problem with a limit.
If you use --manual, you have to create two identical domain names with different values.
9. TXT - Entries
The same name _acme-challenge, but a different value.
PS: Your chain is wrong:
Chain - incomplete
1 CN=*.fullymanagedhosting.com
2 CN=ISRG Root X1, O=Internet Security Research Group, C=US
3 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US
4 CN=DST Root CA X3, O=Digital Signature Trust Co.
Your server should only send 1 + 3, not a root certificate.
Hi
Many thanks. have it working now
system
Closed
June 28, 2019, 11:41am
4
