Cert not working without www
My domain is: www.zedelitoral.com / zedelitoral.com
I ran this command: Followed this instructions> https://certbot.eff.org/lets-encrypt/centosrhel7-apache
It produced this output: I can’t remember
My web server is (include version): Apache/2.4.6
The operating system my web server runs on is (include version): CentOS 7
My hosting provider, if applicable, is: One of the shareholders of my company
Extra> >result of certbot certificate
[root@zedelitoral ~]# certbot certificates
Cannot extract OCSP URI from /etc/letsencrypt/live/zedelitoral.ec/cert.pem
Found the following certs:
Certificate Name: zedelitoral.ec
Domains: zedelitoral.ec www.zedelitoral.ec
Expiry Date: 2018-10-07 15:20:36+00:00 (VALID: 87 days)
Certificate Path: /etc/letsencrypt/live/zedelitoral.ec/fullchain.pem
Private Key Path: /etc/letsencrypt/live/zedelitoral.ec/privkey.pem
If you want the cert to work with both zedelitoral.ec and www.zedelitoral.ec, you’ll need to have both names on the certificate.
Hi @mvelasco93
your certificate is created correct with two names.
https://transparencyreport.google.com/https/certificates/STKWHBTmr7VYV5A21XITg%2FJLWj8u2%2FZ51U7MtarfWXQ%3D
https://www.zedelitoral.ec/ is correct and uses this certificate.
But https://zedelitoral.ec/ uses a self-signed certificate.
So your Apache-configuration of zedelitoral.ec is wrong.
Do you know a guide for what can I check to correct this? Thanks in advance.
The Apache Documentation should help.
What's your configuration of www.zedelitoral.ec and zedelitoral.ec
zedelitoral.ec may have the wrong certificate files.
httpd.conf > https://pastebin.com/raw/WZVebUs6
sites-available/zedelitoral.ec.conf > https://pastebin.com/raw/wK7LZQmb
Hi @mvelasco93,
Regarding this conf:
<VirtualHost *:80>
ServerAdmin info@zedelitoral.ec
ServerName zedelitoral.ec
ServerAlias *.zedelitoral.ec
DocumentRoot /var/www/html/drupal
    ErrorLog logs/error.log
    CustomLog logs/access.log combined
RewriteEngine On
RewriteCond %{HTTPS} on
RewriteCond %{HTTP_HOST} !^www.\.
RewriteRule ^/(.*)$  http://www.zedelitoral.ec$1 [R=301]
</VirtualHost>
If you use RewriteCond %{HTTPS} on on a VirtualHost that is not using TLS it never will match that condition, also RewriteCond %{HTTP_HOST} !^www.\. is not correct you should remove the first dot RewriteCond %{HTTP_HOST} !^www\.
If you only want to redirect all domains to https:///www.zedelitoral.ec remove those rules and add a Redirect.
<VirtualHost *:80>
Redirect permanent / https://www.zedelitoral.ec/
</VirtualHost>
Regarding the certificate issue with domains that are not wwww., could you please show this conf file /etc/httpd/sites-available/zedelitoral.ec-le-ssl.conf?.
Cheers,
sahsanu
I’ll correct the vh conf.
This the ec-le-ssl.conf > https://pastebin.com/raw/HLRhDMnW
I see no problem with that conf. Remember to reload or restart the Apache WebServer once you have modified the conf files.
I had done the redirect thing. So for now, it solves the problem. Thanks!
Great, now you need to know the reason why https://zedelitoral.com is not showing the right cert, I suppose you have defined it on another ServerName or ServerAlias taking precedence to zedelitoral.ec-le-ssl.conf
As a quick test you could edit httpd.conf file and change the order of the includes:
Before:
IncludeOptional conf.d/*.conf
IncludeOptional sites-enabled/*.conf
Include /etc/httpd/sites-available/zedelitoral.ec-le-ssl.conf
After:
Restart Apache and try again.
Anyway, could you please execute this command and show the output?.
grep -Ri zedelitoral /etc/httpd/*
Cheers,
sahsanu
I have changed the httpd conf right now.
As of the result of the grep, it was pretty extensive so the last 2000 lines were copied https://pastebin.com/N0VWUpj5
Great, https://zedelitoral.ec works fine from my side
Thank you! I will leave the redirect so it follows the www site now. If a mod check this, you can close it.
