obstoclades.biz
acmetool --xlog.severity=debug
20210815150755 [DEBUG] acmetool.storageops: Target(obstoclades.biz;https://acme-v02.api.letsencrypt.org/directory;0): best certificate satisfying is , err=Target(obstoclades.biz;https://acme-v02.api.letsencrypt.org/directory;0): no certificate satisfies this target
20210815150755 [DEBUG] acmetool.storageops: Target(obstoclades.biz;https://acme-v02.api.letsencrypt.org/directory;0): requesting certificate
20210815150755 [DEBUG] fdb: enforce permissions: keys/pldseoi4dudgjqrccz6sewd3aj3x6doxgduptj5shle4itiphkaq/privkey 0/0 0/0
20210815150755 [DEBUG] acmetool.storageops: Target(obstoclades.biz;https://acme-v02.api.letsencrypt.org/directory;0): ordering certificate
20210815150756 [DEBUG] acmetool.reshttp: acquire port "[::]:80" "dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k"
20210815150756 [DEBUG] acmetool.reshttp: failed to listen on [::]:80: listen tcp 0.0.0.0:80: bind: address already in use
20210815150756 [DEBUG] acmetool.reshttp: acquire port ":80" "dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k"
20210815150756 [DEBUG] acmetool.reshttp: failed to listen on :80: listen tcp :80: bind: address already in use
20210815150756 [DEBUG] acmetool.reshttp: acquire port "[::1]:402" "dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k"
20210815150756 [DEBUG] acmetool.reshttp: listening on [::1]:402
20210815150756 [DEBUG] acmetool.reshttp: acquire port "127.0.0.1:402" "dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k"
20210815150756 [DEBUG] acmetool.reshttp: listening on 127.0.0.1:402
20210815150756 [DEBUG] acmetool.reshttp: acquire port "[::1]:4402" "dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k"
20210815150756 [DEBUG] acmetool.reshttp: listening on [::1]:4402
20210815150756 [DEBUG] acmetool.reshttp: acquire port "127.0.0.1:4402" "dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k"
20210815150756 [DEBUG] acmetool.reshttp: listening on 127.0.0.1:4402
20210815150756 [DEBUG] acme.responder: writing 1 webroot challenge files
20210815150756 [DEBUG] acme.responder: writing webroot file /var/run/acme/acme-challenge/dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k
20210815150756 [DEBUG] acme.hooks: calling hook script: /usr/local/libexec/acme/hooks/haproxy
20210815150756 [DEBUG] acme.hooks: calling hook script: /usr/local/libexec/acme/hooks/reload
20210815150756 [DEBUG] acme.responder: http-01 self test for "obstoclades.biz"
20210815150801 [INFO] acme.responder: http-01 self test failed: obstoclades.biz: Get "http://obstoclades.biz/.well-known/acme-challenge/dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
20210815150801 [DEBUG] acme.responder: removing webroot file /var/run/acme/acme-challenge/dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k
20210815150801 [DEBUG] acme.hooks: calling hook script: /usr/local/libexec/acme/hooks/haproxy
20210815150801 [DEBUG] acme.hooks: calling hook script: /usr/local/libexec/acme/hooks/reload
20210815150801 [DEBUG] acmetool.solver: challenge start failed: Get "http://obstoclades.biz/.well-known/acme-challenge/dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
20210815150801 [DEBUG] acmetool.solver: challenge start failed: could not install DNS challenge, no hooks succeeded
20210815150801 [DEBUG] acmetool.solver: challenge instantiation failed: challenge type not supported
20210815150801 [ERROR] acmetool.storageops: Target(obstoclades.biz;https://acme-v02.api.letsencrypt.org/directory;0): failed to request certificate: the following errors occurred:
exhausted all possible challenges in authorization "https://acme-v02.api.letsencrypt.org/acme/authz-v3/22122960280" [due to inner error: the following errors occurred:
Get "http://obstoclades.biz/.well-known/acme-challenge/dT6w6ZCAQGpcS8vxriK6rTp1nqSwwdfhIGPBflsee5k": context deadline exceeded (Client.Timeout exceeded while awaiting headers);
could not install DNS challenge, no hooks succeeded;
challenge type not supported]
nginx 1.18.0
FreeBSD 13.0-RELEASE
N/A
no
acmetool-v0.2.1-freebsd-ports
