HOW TO RESOLVER: // NotADirectoryError: [Errno 20] Not a directory:
My domain is: truaccent.com
I ran this command: certbot certonly
1: Apache Web Server plugin (apache)
2: Nginx Web Server plugin (nginx)
3: Runs an HTTP server locally which serves the necessary validation files under
the /.well-known/acme-challenge/ request path. Suitable if there is no HTTP
server already running. HTTP challenge only (wildcards not supported).
(standalone)
4: Saves the necessary validation files to a .well-known/acme-challenge/
directory within the nominated webroot path. A seperate HTTP server must be
running and serving files from the webroot path. HTTP challenge only (wildcards
not supported). (webroot)
+++++++++selected option 2+++++++++++
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): truaccent.com,www.truaccent.com
opencast 17
on Centos09
digitalocean
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.11.0
Hi @tjames,
From around the world shows "Connection timed out" Permanent link to this check report for http://www.truaccent.com as the input and selecting HTTP. Looks like the site is down.
Edit
Here is a list of issued certificates crt.sh | truaccent.com; there are several recently issued certificates, why not just use one of them?
https://tools.letsdebug.net/cert-search?m=domain&q=truaccent.com&d=168
No it's not down. I see the test page. I received multiple certificates but don't know the best process to upload. Now it says I'm locked out with too many attempts within 5 days.
Hi @tjames, did you check with something such as https://check-host.net/ ?
It was up. But after running Certbot it can't find the path to the issued certificate. How to install is the question???
Your certonly request only gets a certificate. You must configure your server to use it. The path to the cert was shown when Certbot got it. You can also see the path with:
sudo certbot certificates
If you need help configuring your server, this is one good reference. Do not enable Stapling as that is being dropped by Let's Encrypt very soon. And, do not enable HSTS until you are fully aware of what it does.
That all said, your nginx server seems completely down. It does not reply to HTTP or HTTPS requests. Review https://letsdebug.net to test HTTP connections. Try SSL Labs for HTTPS: SSL Server Test: truaccent.com (Powered by Qualys SSL Labs)
