Not found when trying to install cert using certbot
My domain is: intueri.no www.intueri.no
I ran this command: sudo certbot --nginx -d intueri.no -d www.intueri.no --staging
(and, foolislhy, 5 timer without staging)
http-01 challenge for intueri.no
http-01 challenge for www.intueri.no
Waiting for verification…
Failed authorization procedure. www.intueri.no (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.intueri.no/.well-known/acme-challenge/sQGa9dyVfMMu9MLMjuKXVVCG8BCGTRH-DGM6h1w23vk: "
404 Not Found
404 Not Found
", intueri.no (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://intueri.no/.well-known/acme-challenge/_5EAUhoJcTDbimxkOcYAFoTdJtSXbuRds6CvddXTlWg: "
404 Not Found
404 Not Found
   Domain: www.intueri.no
   Type:   unauthorized
   Detail: Invalid response from
   "<html>
   <head><title>404 Not Found</title></head>
   <body bgcolor="white">
   <center><h1>404 Not Found</h1></center>
   <hr><center>"
   Domain: intueri.no
   Type:   unauthorized
   "<html>
   <hr><center>"
I’ve quadruplechecked both IPv4 and IPv6 at domain host, verification worked just fine for another site (simple php site, this is a grav cms site)
My web server is (include version): nginx version: nginx/1.14.0 (Ubuntu)
My hosting provider, if applicable, is: https://domene.shop/
Nginx config for site: https://dpaste.de/wcWB
Hi @vimes
I don't find an explicit error. Your ipv6 / ipv4 - configuration looks ok,
doesn't find an error. Looks like you use a content management system GravCMS, perhaps that blocks something.
That
location ~* /(system|vendor)/.*\.(txt|xml|md|html|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ { return 403; }
looks like there are rules used with windows- and linux - systems.
To test: Create two subdirectories
yourwebroot/.well-known/acme-challenge
there place a file with name 123456789 (without file extension) and a simple content.
Then try, if you can load this file via
http://www.intueri.no/.well-known/acme-challenge/123456789
Perhaps there are other rules which block this.
