Not Found only with Certbot
My domain is: simoncircle.se
I ran this command: certbot certonly --nginx --dry-run -d simoncircle.se
http-01 challenge for simoncircle.se
Waiting for verification…
Failed authorization procedure. simoncircle.se (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://simoncircle.se/.well-known/acme-challenge/wQpMVaGjQJk7dOMc2avtAaEqB8PvDJN8XAqmt2G4W_A [81.231.60.74]: “\r\nDocument Error: Not Found\r\n
Access Error: 404 – Not Found
\r\n
   Domain: simoncircle.se
   Type:   unauthorized
   Detail: Invalid response from
   [81.231.60.74]: "<!DOCTYPE html>\r\n<html><head><title>Document
   Error: Not Found</title></head>\r\n<body><h2>Access Error: 404 --
   Not Found</h2>\r\n<p>"
My web server is (include version): nginx/1.14.0 (Ubuntu)
My hosting provider, if applicable, is: Hosting on my own server
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
When I use the --debug-challenges option, then take the location of the key and put into a browser, it works just fine but the certbot cannot verify it.
Hi @SimonCircle
I see, you have already checked your domain via https://check-your-website.server-daten.de/?q=simoncircle.se
Port 80 is open, your website answers with a correct http status 404 - not found.
So try to find your root (in your vHost file) and use it:
certbot run -a webroot certonly -w yourRoot -d simoncircle.se -d www.simoncircle.se
To check if you have found your correct root, create the two subdirectories
root/.well-known/acme-challenge
there a file (file name 1234), then try to load that file via
http://simoncircle.se/.well-known/acme-challenge/1234
Thanks for the quick reponse :grinning:
My root: /var/www/simoncircle.se
When I run: certbot run -a webroot certonly -w /var/www/simoncircle.se/ -d simoncircle.se -d www.simoncircle.se
I just get: certbot: error: unrecognized arguments: certonly
I have created /var/www/simoncircle.se/.well-known/acme-challenge/1234, with hello in it. If you curl that with curl http://simoncircle.se/.well-known/acme-challenge/1234, you get 200 OK and the response is Hello
I love my errors - remove the run command :wink:
There are some combinations which doesn’t work. But I have to do too much other things.
Really? I have a 404 - not found:
Access Error: 404 -- Not Found
Can't locate document: /.well-known/acme-challenge/1234
Must work with non-www and www.
It’s not an Nginx server.
Nginx’s 404 Not Found pages look different.
The Server header is "App-webs/".
Edit: If I open http://simoncircle.se/ in a browser, it redirects to a .asp Hikvision login page.
So, I got this when I curl it
GET /.well-known/acme-challenge/1234 HTTP/1.1
Host: simoncircle.se
User-Agent: curl/7.58.0
Accept: */*
< HTTP/1.1 200 OK
< Server: nginx/1.14.0 (Ubuntu)
< Date: Thu, 14 Mar 2019 17:15:02 GMT
< Content-Type: application/octet-stream
< Content-Length: 6
< Last-Modified: Thu, 14 Mar 2019 17:00:36 GMT
< Connection: keep-alive
< ETag: "5c8a88b4-6"
< Accept-Ranges: bytes
Hello
but when I used this online site which lets you curl stuff: https://onlinecurl.com/, I got >
<html><head><title>Document Error: Not Found</title></head>
<body><h2>Access Error: 404 -- Not Found</h2>
<p>Can't locate document: /.well-known/acme-challenge/1234</p>
</body>
</html>
Could it have something to do with that I am running this inside a LXC Container and not a VM
Are your DNS records correct? Is 81.231.60.74 the correct IP?
Port forwarding settings?
Do you have a Hikvision surveillance camera or something?
That is really weird, All my DNS records are correct and all my portforwarding is also correct
That's interesting, my tool doesn't see a redirect.
So that looks like a bot detection: Users -> login, bots -> nothing.
I have Hikvision stuff but they are not portforwarded and 80, 443 goes to my LXC Container
It uses JavaScript. :slightly_frowning_face:
window.location.href = "doc/page/login.asp?_"+nowDate.getTime();
I just get 403 Forbidden (NGINX)
I check the content only, if it is https. There the tool sees redirects and meta refresh.
Should add it with http.
I have just changed the IP of the LXC Container and changed my port-forwarding settings accordingly, to ensure that it was not a IP overlapping issue. Because all my websites were redirecting to the Hikvision stuff before on my mobile phone.
No change for me yet.
Port 80 is the Hikvision.
Port 443 is a connection refused error.
So everything on my local network works just fine, but outside it just does not work. I will try restarting my router.
I would suggest combining the webroot authenticator with the nginx installer:
certbot -i nginx -a webroot -w /var/www/simoncircle.se/ -d simoncircle.se -d www.simoncircle.se
But firstly, your router/portforwarding/VM/otherstuff needs to be OK :slight_smile:
